Rc10ntc3
#6511
running os 12cv-r(p) this is a side exhaust, infield i have no problems there, i am shifting into second gear because after the turn into the straight that is where it shifts/jumps a little. i was thinking that my gear mesh could be the problem so i did it all over again and still nothing. going to try the gearing maybe that will do something. this really has stumped though. but that is racing
#6512
#6513
Re: V2 Upgrade question
Originally posted by revzalot
I'm currently upgrading my rear suspension to v2. I just got one concern. Is it normal for the turnbuckle to make contact with the rear tower when you push up the rear arm? Btw, shocks are not installed yet.
#6514
G'day
Hi Guys,
I'll be running an NTC3 at our next race meeting for the first time. The one I have is a factory team edition with all the goodies.
Having previously only run belt cars, I was wondering if it was normal for the drive line to make a little bit of gear noise?
When the car came it had previously been assembled (a little heavy handedly I must say), but never run. I stripped it down and checked the shims as it was a little noisy and one of the front shims had more than it should have.
Is there anything else that I need to know about this little bit of noise in the drive line? Car moves freely and rolls a lot more freely than my belt cars ever did!
Any help would be appreciated.
Cheers,
Michael.
Cheers,
Michael.
#6515
Re: G'day
Originally posted by Z00M
Hi Guys,
Cheers,
Michael.
Hi Guys,
Cheers,
Michael.
#6516
Re: G'day
Hi Guys,
Cheers,
Michael.
Hi Guys,
Cheers,
Michael.
#2 things you have to know is..........FT NTC3 (with front 1-way) will required some drag brakes (or using ABS).......since you are belt driven owner before, you probably know that....but for me, I prefer to use front ball diff and using a lot of BRAKING....that is the beauty of NTC3............my car ran much faster and turn much better by using brake and front diff then how I drove on Serpent 705....totally different way to drive but my lap time is much faster.
#6517
Thanks very much for the advice! Much appreciated.
I actually got the car finished last night and drove it for the first time today!
Talk about a snappy performer. It has a lot more acceleration than my previous car. I'm only running a Picco Omega XT .12 (1hp) motor in it at the moment and it rips.
The handling is quite good, but I just need to work on the setup to get that sorted out (too much power on steering at the moment).
I hit a couple of kerbs and it didn't fall apart like I thought it would according to all the hype you read about the NTC3 being fragile. lol.
I did notice that the rear toe setting (V2 suspension) had changed by about 1.5 degrees so this could account for why it ended up having too much steering on power.
Anyway, just wanted to say thanks for the tips. I'm very happy with the car and can't wait for the next race meeting now.
Cheers,
Mike.
Cheers,
Mike.
#6518
hey guys, im breaking in a ntc3 rtr plus with a friend, its running pretty good, but it glitches like mad, after 20-30 feet it goes all apeshit and full throts, it has a throt return spring, and its on am ch 6 right now. also, do any of you know how to get the rpm front bumper on? ive been trying and ive gotten no luck.
thanks
thanks
#6519
Bumper
I can help you with the bumper issue
Associated in all their glory has produced a different bumper for the NTC3 RTR vs NTC3 Kit. Some bright spark thort this was a cool idea. Note that I own the old RTR and not the plus
You would need items:
http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXBLY1
sadly you'll only need the three pads
and this
http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXBLX5
Make sure though that this is still the case with the PLUS
The rest is RC 101. Good luck
and this
#6520
Zoom,
The change in the rear toe could be attributed to the pvot balls. Have you checked them since hitting the curb? I mean actually unscrewing them to see if the are bent.
NTC3 is fine but the pivot balls are sensative. Better the pivot balls than something else.
John
John
#6522
Re: Anyone tried this clutch set?
Clutch Set
Clutch Set
2 shoes or 3 shoes clutch respond much better and lighter, not to mention way cheaper....
#6523
im pending on a deal with a guy for his used ntc3, what parts do i need to upgrade the entire rear to version 2? please post links,
and is the collari xs .12 engine any good? would the os a3 plug work for it?
what do u guys use to clean ur nitro cars, this one has like grease and grime and nitro residue on it, whats the best way to get it off?
#6524
The V2 rear suspension part numbers are on the www.rc10.com website (just surf through to the NTC3 section).
For cleaning cars, take the electrics out of the car and then douse the whole lot with either denatured alcohol, nitro cleaner in a spray can, or buy a squirt bottle and a gallon of methylated spirits and clean away. I find the metho to be the most economical solution.
As for my posted issue the other day about extra rear steering, well, ol' fat fingers Z00M strikes again - I misread Barry Bakers setup (or didn't know how to use the droop guage ) and set the rear end to only 2mm of droop.
I adjusted that, changed the front blade to full verticle and the car is now sweet!
#6525
Registered User
I've used the K-factory and the Kawara centax, I think they're over rated. The adjustability is sweet but to me the clutches are too small and over heat, causing disc and thrust brg. failure. The 3 shoe K factory clutch is all we use now.
It's a better clutch than the AE because of the clutch shoe material and it comes with a hardened flywheel. No more clutch shoes digging into the flywheel!
