Like Tree2Likes
Rc10ntc3
Old 06-29-2004, 08:31 PM
  #6526
thefuzzclub's Avatar
Default steering problems
coming from a corner to the main straight, my steering does not go back to center line. at rest, when i turn the steering left and release it the tires doesn't go back exactly to where the center is. the same thing when i turn my steering to the right. is there something i need to modify? basically my servo saver is stock.
thefuzzclub is offline
Old 06-29-2004, 10:09 PM
  #6527
soc123_au's Avatar
Are you using a Hitec servo?
soc123_au is offline
Old 06-29-2004, 10:30 PM
  #6528
Z00M's Avatar
Trader Rating: 15 (100%+)
Default Steering
I was reading some old posts (between page 170 and 180) and some dudes found that problem to be one of three things.
1) The servo saver spring was very sad and they replaced it with either the factory optional spring or with an RC10GT Slipper spring.
2) The ball cups on the steering blocks were tight (this could be tested by removing the steering links and making sure they are free to rotate in both directions).
3) The bearings in the swing rack need cleaning/replacing.
I guess on top of this, you might also need to look at servo torque/centering ability etc if it's not a mechanical issue.
Hope this helps.
Cheers,
Mike.
Z00M is offline
Old 06-29-2004, 10:46 PM
  #6529
steering servo is futaba 9402
Old 06-29-2004, 10:48 PM
  #6530
Default ZOOM
thanks for your tips, i already replaced the servo saver spring with the stiffer one. i will check the ball caps as well as the bearings
Old 06-30-2004, 04:21 PM
  #6531
DMACK's Avatar
If you have bent on or more of the pivot balls, that can also drastically effect the centering of the steering even with a very strong servo.
Take the control arm off your steering servo and move it by hand. It should be smooth as glass, and not bind. If it does take off the control arm to both of the steering blocks and move them by hand. That will show you which one is screwed up, and make it easier to fix. Even a small bend in a pivot ball can jack up the steering.
DMACK is offline
Old 06-30-2004, 04:44 PM
  #6532
DMACK,
thanks for the reply. i will also check the pivot balls. i didnt know this can affect the centering of the steering. actualy i havent check them since the time i got the kit last 2002.
Old 06-30-2004, 05:27 PM
  #6533
Z00M's Avatar
Just in case anyone is after one, I have my second Factory Team V2 NTC3 up for sale (in Australia). It comes with all the usual FT goodies, plus some option parts. Carbon fibre radio plate and side plate, K-Factory low CG tank, 3 shoe clutch, alloy brake bearing cover and 'the fix' in the front end. Includes all the stuff from the original kit as well (incl the blue FT 2 chamber pipe)
I was bidding on 2 of these on ebay to try and win one and ended up winning 2! lol. So one has to go for what I paid for it.
A$375.
I also have an STS RS5 turbo that is brand new that I can throw in for an extra $160.
I know this isn't the for sale section, just thought if there was someone wanting a spare car or to move up to a FT car then I would post it here.
Cheers,
Mike.
pm or email me for details.
Z00M is offline
Old 07-01-2004, 09:56 AM
  #6534
Trader Rating: 17 (100%+)
Default Re: steering problems
No servo will give you absolute center everytime you return your steering...when you say they cannot be center, is that UNACCEPTABLE (like using some cheap servo or Hi-tec servos)or just a hair...?....but again, my money is on your pivot balls, 1 or few of them are bent...
Also, do not tighten up the end cap of the pivot ball, I made a mistake last week on the rear and lost a lot of rear traction cause my rear right arms cannot travel smoothly because the end cap was tightened too much.
Solara is offline
Old 07-01-2004, 02:47 PM
  #6535
jt6
jt6's Avatar
Hey Rookie - is this with the new or old rear? Or both?
Just curious cause I have run into this same symptom and never thought of the caps being too tight?
jt6 is offline
Old 07-01-2004, 05:29 PM
  #6536
Default Re: Re: steering problems
Hi Rookie,
Yah you're right pivot balls were bent...
Old 07-01-2004, 06:13 PM
  #6537
revzalot's Avatar
Smile
I don't think this guy is a rookie at all.
revzalot is offline
Old 07-02-2004, 04:33 PM
  #6538
has anybody tried the RD logics turbo pipe? I heard that it hits the fuel tank. Has anybody heard of this? Thanks for you input
thomasf is offline
Old 07-02-2004, 09:38 PM
  #6539
Number 11's Avatar
I just started using the blade front sway bar. My question is if the bar is horizontal or vertical what benefit is it to the car. For some reason I can't find any info on what happens when I adjust the blades.
Number 11 is offline
Old 07-02-2004, 09:45 PM
  #6540
revzalot's Avatar
The more vertical the blade the stiffer. What confuses me is when someone says, "I adjusted the blade 15 degrees." Is that 15 degrees from the horizontal?
revzalot is offline
