Xray NT1
#3901
cheers
#3902
No really, i picked up the car from the table after the winter stop, it sticked to the table because of the diff leaking. The diffs had new orings and even had extra glue sealing on the outside...
#3904
I use liquid gasket to seal op the diffs, with the xray o rings i would need a new one every time i open up a diff.
My diffs don't leak at all, left them all winter in the original cardboard box and not even a single stain.
If you build xray diffs properly they don't leak.
#3905
I use ultra black permatex RTV and when you remove the cap it usually stays as one piece on the main case side if you aren't using a new diff case. Keeps the mess down a bit. and since it makes its own little gasket it makes dealing with it at the track better since the little oring is captured. Hope it works for you. Cheers
#3906
#3907
me and most of the team drivers that I have talked to fill the diffs full. I have personally just had better results with using rtv to help it seal. just a thought...
#3909
Same here, liquid gasket and never have any leak. We run on a track with around 80-90 feet straight with tight in field most of us use front one-way with 30,000 rear. Very stable but wants to try may be 35,000 at the rear this weekend to get the tail a bit quicker.
#3911
no, I ment the guys like ralph burch etc, I also happen to run a full diff. this from the guy with a trader rating of -1 lol.. does everyone just hang out on the computer looking for an argument?
18Likes
is it because my large oring is getting old?
so what are you trying to say? you are a team driver now
