Like Tree7Likes
Old 06-28-2010, 01:23 PM   #5401
Originally Posted by Tag View Post
hi guys, just bought a LRP .12 team spec engine, just wondering if this enigne will fit into nt1 without modification , i am asking because i had fitment problem with a sirio evo4, thanks !
The Lrp will fit without an issue or modifications
jelayne is offline   Reply With Quote
Old 06-28-2010, 01:58 PM   #5402
lil-bump's Avatar
Trader Rating: 83 (100%+)
You should have no problems with the Lrp engine. It's a picco based engine
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 06-28-2010, 02:25 PM   #5403
Tag
Tag's Avatar
Trader Rating: 31 (100%+)
thanks for the help guys !
* Serpent 966 TE Novarossi 35+21, Airtronics M12 *
Tag is offline   Reply With Quote
Old 06-28-2010, 02:55 PM   #5404
NikoRacing's Avatar
Originally Posted by RC MARKET View Post
XRAY Released 2 option parts
& Low Friction belt V2
Are this part already available?
Very interested in the aluminium front middle-shaft holder (which seems to have bushings for bearings)
Last weekend I tried Capricorn's 18, 19, 25 and 27t kevlar pulleys and front & rear belts... the car is simply spectacular! (also with the standard side-belt) It's incredibly smooth!!
No plays on the shaft. Very precise mounting. I only made holes to let the dust going out and maintain the pulleys a little more clean.
It's a pity that Capricorn doesn't make also the 20t pulley for xray
Also the red brake pads are very good. Better than the KM-Racing which I used for almost 2 years.
NICOLA PEZZOTTI - italian F1 cat. driver - Serpent 747 - HIPEX exhaust system - HOTRACE tyres - SANWA M11X
NikoRacing is offline   Reply With Quote
Old 06-28-2010, 03:02 PM   #5405
Originally Posted by NikoRacing View Post
Are this part yet available?
Very interested in the front middle-shaft holder (which seems to have bushings for bearings)
Last weekend I tried Capricorn's 18, 19, 25 and 27t kevlar pulleys and front & rear belts... the car is simply spectacular! It's incredibly smooth!!
Atomicrc has all those hopups already.
And let me tell you they `re the cats meouw,lol,lol,lol.
Check it out, you won`t be disappointed.
Best hopups for the NT1 i think.
Best pads bar none, best brake lever bar none.
Best middle bearing block bar none.
RROL and LOU`s where only real racers race.
Weapons of choice,NT1 2010 , X-Ray T3 x 2, X-Ray X10 X-Ray all the way baby.
Futaba 4pk,gq tires,jaco tyres,odonnel fuel,T-Power batteries, tekin and nova powered.
Don`t blame the car, when you know you can`t drive.
Sponsor, me , myself and I.
nitro ho is offline   Reply With Quote
Old 06-28-2010, 03:45 PM   #5406
NikoRacing's Avatar
I already have the middle shaft holder (and brake lever) by Atomic but I've not mounted it on my 2010 NT1...I was just expecting the xray original one
I prefer composite pulleys than the aluminium ones. I know that the alu are very good to see and already tuned but them are little too hard for the low-friction-belts....and believe me never smooth as kevlar pulleys!
Old 06-28-2010, 04:14 PM   #5407
RC MARKET's Avatar
Yes instock now !
but last some pcs
Cpricom belt is ultre low friction ,but too short life !
RC MARKET is offline   Reply With Quote
Old 06-28-2010, 07:38 PM   #5408
danny250r's Avatar
Trader Rating: 41 (100%+)
how is the 3 racing receiver mount is bigger then the xray one . not the box just the plate. thx
danny250r is offline   Reply With Quote
Old 07-03-2010, 06:13 AM   #5409
picco007's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to picco007 Send a message via Yahoo to picco007
Hey guys, I'm needing some advice or help. I bought an NT-1 EC a while back that had been barely run at all. I know the gentlemen that built it and he knows what he is doing. I just ran my first race with it last weekend and want to break it down to rebuilt it. I remember I used to use a grease or something to rebuild the dog bones where they fit into the drive cups. Does anyone know what should be used for this?
Also for the clutch thrust bearing there was something that we used to use to grease these as well, do yo have any advice on what should be used there as well?
I used to race a while back and took some time off to concentrate on electric....now i'm back...
Thanks in advance.
EA Motorsports
picco007 is offline   Reply With Quote
Old 07-03-2010, 08:10 AM   #5410
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Thanks in advance.
I use Associated Black grease for the two spots.
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 07-04-2010, 10:15 AM   #5411
picco007's Avatar
Thanks.
EA Motorsports
Old 07-04-2010, 10:53 AM   #5412
danny250r's Avatar
ok well i got the car started no prob, but it just revs up without moving the belts just barely start to move after i rev up pretty high how do i adjust this thanks
Old 07-04-2010, 12:27 PM   #5413
Trader Rating: 24 (100%+)
Maybe the clutch is to tite
RANDY SMOOTH is offline   Reply With Quote
Old 07-04-2010, 04:51 PM   #5414
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Either your clutch nut has to much preload, or your flywheel nut is loose. I would say those would be the most likely problems. If its the first back off the clutch spring preload nut 1/4 turn till it grabs properly.
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 07-05-2010, 04:00 PM   #5415
I got a used NT1 08 roller from a friend of mine and I'm trying to break in an engine, but the clutch won't engage. Wheels don't move at all with pretty high revs.
Flywheel nut is tight
gap is about .7mm
preload is 10.2 mm (10.2 from end of shaft to top of the preload nut)
clutch nut is about 9.35 mm from end of shaft
Anyone have any ideas. Thanks
mikedoo3 is offline   Reply With Quote
