Xray NT1
#3916
Permatex Ultra black RTV. its found at just about every auto parts store I have ever walked into.
#3917
#3918
#3920
#3921
i see grubs on the top deck above steering servo on a plate screwed on. so not sure about that one. im sure he will let ya know. might head down this weekend so Grub can chase the snake again
#3922
I guess he expect to have more chassis flexes by doing that.
#3923
For the diff oil, i always use 80k in the front and 40k in the rear. Only when i run on a really tight track i switch to a solid in the front and 30k in the rear.
#3924
I am thinking the reg interfered?? also i was a bit reluctant o putting the reg in front of the fuel tank due to any fuel which could spill onto it
sounds like you got that mm 353 going well?cheers
#3925
hey, yep I have mine sitting on the transponder but I had a few missed laps last week cost me a race even thou I was 2 laps ahead of the guy who won
cheers
i used an under powered (compared to the M353) a Mega MF, it was all the car. it was a virgin before the day, first bit of track time it saw. the snake is fast
#3926
hey guys i have been experiencing understeering problems since the day i go the car. last time i think i solved the problem but will a 100,000 sct oil in the front help, have been using 80,000 so far?? i am using 30,000 in the back. Thank you
#3927
Hi,
The last few weekends I'm having some problems with the fly weigths of the clutch.
After some runs the weigth holes are turning oval or there is even a crack at het side.
Clutch setting seems normal:
Clutch gap is 0.6 mm
Xray hard spring at 1.4 mm
How can I get this solved, every weekend new weights is expensive too.
#3929
Hi,
#3930
Hi,
18Likes
