Like Tree18Likes
Xray NT1
Old 02-16-2009 | 11:50 PM
  #3766
RC MARKET's Avatar
Originally Posted by bboy
Any body knows how to use this transponder part:
http://www.teamxray.com/teamxray/pro...p?prod_id=1985
What is the difference between mounting in front vs on the side?
Cheers.
I'm used this !
http://rcmarket.com.hk/product_info....oducts_id=5476
RC MARKET is offline
Old 02-17-2009 | 01:20 AM
  #3767
aussies1129's Avatar
Originally Posted by diesel
Hi there,
I have difficulties in removing my 2nd speed pinion gear. Any tips or is there a
tool to clamp down the clutch bell ? I have both pinion removal tools with me.
Many thanks.
mate have you tried the xray pinion removal tool?
xray 339901
cheers
aussies1129 is offline
Old 02-17-2009 | 01:39 AM
  #3768
does anyone know when the new nt1 09 spec release date is? and how much will it be going for??????
Destroyer_2088 is offline
Old 02-17-2009 | 08:47 AM
  #3769
diesel's Avatar
xray 339901
cheers
Yeah thanks...I was using that. Just that there isn't a tool for me to hold the clutch bell down to unscrew the bigger pinion.
Btw, does anyone know the spring rate for the stock silver springs that came with the car? I can't get on Xray's website...anyone experiencing that too?
Cheers.
diesel is offline
Old 02-17-2009 | 08:54 AM
  #3770
D-nicest's Avatar
Cheers.
Here's the tool that would hold the clutch bell while you use the pinion gear tool. It's also a Flywheel holder...
http://hudy.net/xhudy/images/ind_182010_promo.jpg
The car comes with 33 weight springs in front and 28 in the rear
D-nicest is offline
Old 02-17-2009 | 02:25 PM
  #3771
Originally Posted by Gseventeen
I'm using the exceed 7.4 volt lipo, it is very light and power is great. only charge every second race meet so far .
...which i suggested you should run about 1 year ago, and you said "meeehh it's too light" then you went on about something about weight etc etc
"get a brass battery tray" i said
"nahh because...*bla bla bla" i only heard the first few words then i tuned out when i realised you wouldn't listen
TomB is offline
Old 02-17-2009 | 11:29 PM
  #3772
yep xceed is the way to go nice and cheap too
Old 02-18-2009 | 12:01 PM
  #3773
solitude127's Avatar
Thanks for the help
Originally Posted by asw7576
Relax the four top screws and four bottom screws. Tigthen all the screws at the position where you can spin the gears the most freely.
solitude127 is offline
Old 02-19-2009 | 12:57 PM
  #3774
breez1090's Avatar
I tried to mount my throttle servo under the upper deck instead of being on top but i noticed it wouldnt work do you think getting a low profile servo would be a good idea
breez1090 is offline
Old 02-19-2009 | 02:02 PM
  #3775
rcfoolz's Avatar
I've been running the low profile servo's in the car for more than a year now with no problems. And for the throttle servo, it is under the deck. I've just switched over to the half hight servo's to run in the steering..(KO servo's)
rcfoolz is offline
Old 02-19-2009 | 03:00 PM
  #3776
breez1090's Avatar
you use em for both steering and throttle ? whats the model number for the ko low profile servo .....are they fast?
Old 02-19-2009 | 05:08 PM
  #3777
rcfoolz's Avatar
PDS 2413 and Futaba 9550 I just switched to the KO servo's
rcfoolz is offline
Old 02-19-2009 | 05:28 PM
  #3778
breez1090's Avatar
WHICH ONE IS FASTER
Old 02-19-2009 | 05:30 PM
  #3779
D-nicest's Avatar
WHICH ONE IS FASTER
I believe the KO is faster and has more torque. Whats goin on kid
D-nicest is offline
Old 02-19-2009 | 05:38 PM
  #3780
breez1090's Avatar
thanks....wassup D hows xray treating you
