Like Tree6Likes
Old 12-19-2007, 02:28 AM   #2266
asw7576's Avatar
I forget HongKong is the best place to buy everything.
Old 12-19-2007, 04:24 AM   #2267
Super Moderator
Snowy's Avatar
Trader Rating: 14 (100%+)
Originally Posted by MAVICXXX View Post
i have run novarossi plus base and picco idm before,they fits nice,except for sirio,i need to do little dremel work on the crancase mounting holes.
Did you have a problem with the crankcase itself? I just tried to fit a RB Matrix but the bottom of the crankcase is too wide because of the cooling fins. Has anyone else tried a RB Matrix in this car?
The OS Speed & Sirio EVO 3 fit perfectly.
Snowy is offline   Reply With Quote
Old 12-19-2007, 01:39 PM   #2268
Snowy,
I'm running an RB Matrix and I know at least another two guys that are. Although it is a tight fit they do go in without any mods.
Try having all the screws loose, fit the engine and then tighten them up. I didn't think it was going to fit either but after loosening the screws it worked.
Great combination by the way!
Good Luck.
CDS70 is offline   Reply With Quote
Old 12-21-2007, 03:14 AM   #2269
S710_Nut's Avatar
Hi
I have a question... If i was to put a JLR Ret Dot into the NT1, do i need to make any changes to the collet or anyting for the clutch? And do i use the Xray collet or the one that comes with the engine?
Thank you in advance
S710_Nut is offline   Reply With Quote
Old 12-21-2007, 09:13 AM   #2270
Osiris 75's Avatar
Trader Rating: 17 (100%+)
Originally Posted by S710_Nut View Post
Hi
You can use the one that comes with the engine, but you will have to sand it down about 1mm, or you can just get the Picco one Xray sells!
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 12-22-2007, 12:14 AM   #2271
S710_Nut's Avatar
Thank you for the reply... what length should the collet be then? I currently have the JLR in a 2nd hand car i bought, so i am not sure if it is the engine collet or something different.
Maybe it would be easier to install my STS into the NT1
Old 12-22-2007, 04:29 PM   #2272
Osiris 75's Avatar
I'm not sure what the size is, but you can buy one from nexus racing. The STS may be the quick fix for now!!
Chris Kemper
Old 12-25-2007, 01:12 AM   #2273
MAVICXXX's Avatar
sorry friend,have not came across this engine before,but i have friends running the matrix engine,they didnt discuz this with me and was running quite well.i heard its the same base as sirio,more alike sounds and internally similar.
MAVICXXX is offline   Reply With Quote
Old 12-25-2007, 12:04 PM   #2274
kaotickc's Avatar
Trader Rating: 43 (100%+)
If you measure the inside of your engine mounts, its 25.5mm width and if look at sirio based motors, their width is 26mm. Now they will fit, it will just be a tight fit where most O.S.-Picco-Nova based are 25.5mm so they fit perfectly.
kaotickc is offline   Reply With Quote
Old 12-25-2007, 07:55 PM   #2275
Undies's Avatar
Default Brakes Screws
Hi
Just wondered if the manual is correct with screwing the screws all the way into be flush with the bulkhead? Doesn't leave alot of room for brake disc?
Undies is offline   Reply With Quote
Old 12-25-2007, 10:37 PM   #2276
Nexus Racing's Avatar
Hi
I put the Red Dot in mine and used the stock collet without any problems (the Xray one was not available then). I'm not sure why Osiris had to grind his...maybe there are different types out there?
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 12-26-2007, 06:41 AM   #2277
Send a message via ICQ to _cyclops_
Originally Posted by Undies View Post
Hi
Try it... you will find that there's no place for the brake disk anymore...
Screwing them flush leaves to little space (at least, that's what happend here)
Just make sure the axle is moving freely with the brake in natural position and with as less play as possible before the brake initializes...
_cyclops_ is offline   Reply With Quote
Old 12-27-2007, 12:14 AM   #2278
Z-Mann's Avatar
does the ufo 2 clutch work on the nt1???
Z-Mann is offline   Reply With Quote
Old 12-27-2007, 12:39 AM   #2279
asw7576's Avatar
Do you want to get shot ?
Old 12-27-2007, 09:47 AM   #2280
joebiii's Avatar
Trader Rating: 16 (100%+)
Hi guys , just like to ask if anyone is using the " Xray NT1 Composite Front Holder For Personal Transponder" ? and if possible share some pics of it installed in the car, coz I have one and not sure how its attached ..
joebiii is offline   Reply With Quote
