Like Tree7Likes
Old 02-13-2009, 07:59 AM   #3751
Originally Posted by endy0430 View Post
I was thinking of getting me an NT1 but I've heard from a couple of my LHS that parts are hard to get and expensive. Can you guys shine some light on this before I spend my $$$$$. Thanks
You will have no trouble getting parts, and neither should your lhs.
Their prices are about the same as other brands. Lots of good mail order
places out there to get parts from.
Nexus has been mentioned, and Ashford is really good as well. But if you want to support your lhs, they should have no problem getting parts from RC America.
WARDO is offline   Reply With Quote
Old 02-13-2009, 08:19 AM   #3752
musti72's Avatar
everyone says that xray parts are expensive... but the parts are more durable than other brands, so you dont pay much more compared to other brands.
musti72 is offline   Reply With Quote
Old 02-13-2009, 08:32 AM   #3753
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to ToysRUsKid
This is why I hate LHS's and I want to own one someday. The parts are not hard to get, most LHS's don't stock them because this is a race touring car and they stock parts for mostly bashing. Most of your parts will come from online shops like nexusracing, kamikazehobbies, ashfordhobby, amainhobbies, etc. My local shops don't stock the parts either, but I never having a problem with any of these places not having what I need unless it's really new to the market.
Yes they are more expensive than the other brands, but they also don't break easy so you get what you pay for.
Dorian Tisdale - Professional RC Driver Wannabe
ToysRUsKid is offline   Reply With Quote
Old 02-13-2009, 09:17 AM   #3754
diesel's Avatar
Hi there,
I have difficulties in removing my 2nd speed pinion gear. Any tips or is there a
tool to clamp down the clutch bell ? I have both pinion removal tools with me.
Many thanks.
diesel is offline   Reply With Quote
Old 02-13-2009, 09:51 AM   #3755
RayJ's Avatar
Originally Posted by diesel View Post
Hi there,
Many thanks.
I don't know which pinion tools you have, but sometimes the 2nd gear pinion will be hard to remove. One thing to try is heating the pinion with a propane torch. Don't overdo in heating to remove the anodizing, but just heat it up. If you are using a steel clutch bell and aluminum pinion.... the aluminum pinion will expand more than the steel. It should come right off.
RayJ is offline   Reply With Quote
Old 02-13-2009, 12:50 PM   #3756
endy0430's Avatar
Trader Rating: 25 (96%+)
Default thanks
Yo thanks for all the responses you guys have help me make up my mind..cant wait to get it and start racing...
Once I get it I ll ask for some advice on which engine and pipe you guys are using...
Also I'll post up some pics....
endy0430 is offline   Reply With Quote
Old 02-13-2009, 12:57 PM   #3757
DS Motorsport's Avatar
Next time put a little dab of copper paste between the bell and the pinions.
If you don't aluminium and steel will bind in to each other because of a chemical reaction. Same for engine screws.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 02-14-2009, 09:10 AM   #3758
bboy's Avatar
Any body knows how to use this transponder part:
http://www.teamxray.com/teamxray/pro...p?prod_id=1985
What is the difference between mounting in front vs on the side?
Cheers.
Serpent 960-08 + Max XL9
XRay NT1 + Max XXL3
bboy is offline   Reply With Quote
Old 02-14-2009, 11:22 AM   #3759
lil-bump's Avatar
Trader Rating: 83 (100%+)
+1
I use the copper paste also. I would damage at least one screw everytime I tried to remove my engine.
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 02-14-2009, 06:34 PM   #3760
freestyles's Avatar
Trader Rating: 14 (100%+)
Hi there,
Many thanks.
If you have two holes in your bell you can put a strong bit of wire through them like a wire from a pipe stay, then hold onto it inside the bell with some multi grips or vice grips then you said you had those tools to fit around the pinion. Just get the one that fits and swing off it
Hope that helps ya.
This public service announcement was brought to you by the letter "B" and the number "9". Thanks for watching.
freestyles is offline   Reply With Quote
Old 02-15-2009, 11:07 AM   #3761
diesel's Avatar
My endbell is the stock one with only one hole. Will be changing to the
lightweight one...much easier to work with besides being lighter. Will try the
copper paste trick on my new endbell. Thanks guys.
Old 02-15-2009, 04:05 PM   #3762
solitude127's Avatar
Trader Rating: 21 (100%+)
How do you adjust the gear mesh? I read in the instructions and it said to loosen the lower screws on the engine mount. On my chassis, there is no room for the lower screws to move, so the mesh pretty much stays the same. Can anyone help? Thanks
solitude127 is offline   Reply With Quote
Old 02-16-2009, 01:33 AM   #3763
i'm sure i might have ask this question before but what battery packs are you using in this car
zxknight is offline   Reply With Quote
Old 02-16-2009, 01:46 AM   #3764
Gseventeen's Avatar
I'm using the exceed 7.4 volt lipo, it is very light and power is great. only charge every second race meet so far .
NEW CAR (watch this space) POWER:NOVA 353 TUNED, JP BLACK MODDED,OS SPEC11
SPONSOR= EDV ELECTRICAL!! 9699-9961
'' THE LAD COMING BACK SOON!!!!
Gseventeen is offline   Reply With Quote
Old 02-16-2009, 02:27 AM   #3765
asw7576's Avatar
Relax the four top screws and four bottom screws. Tigthen all the screws at the position where you can spin the gears the most freely.
