Like Tree7Likes
Old 03-06-2009, 02:20 PM   #3871
rc-sonic's Avatar
Originally Posted by RC MARKET View Post
CSO
7075 T6 HARDCOATED MIDDLE SHAFT (2.2g)
& FLYWHEEL (4.4g)
The quality seems pretty rough…… I believe xray original options are much better.
RC-SONIC
rc-sonic is offline   Reply With Quote
Old 03-06-2009, 05:12 PM   #3872
DS Motorsport's Avatar
Originally Posted by HulkNT1 View Post
Hello
What Shocks Spring are compatible with the Xray one that out there.. THe NT1 has shorter shock spring in the front than the back what brand sell the same thing short in the front than the back???
Felix
Serpent springs, perfect fit. I run the blue or red serpent springs.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 03-06-2009, 05:26 PM   #3873
HulkNT1's Avatar
DS you run red the front and blue in the back??
HulkNT1 is offline   Reply With Quote
Old 03-07-2009, 02:09 PM   #3874
Most of the time i run the blue's all around, these are comparable to the purple xray ones, the reds are comparable with the light purple. When grip is low i use the red's in the back.
P1-RC.com
Old 03-08-2009, 05:39 AM   #3875
aussies1129's Avatar
Trader Rating: 74 (100%+)
hey guys just put on the light weight upgrade xray first gear hub 335531 and I only ran it for no more than 5 mins and it started to free spinning in 1st gear is that a fault that cant be fixed or could something else that may have caused the problem, I have checked it and it is clean and free of any oil in the bearing and on the shaft?? do I need to have it replaced?any suggestions would be appreciated?
cheers
Proudly supported by......
Premier Model Supplies Pty Ltd
H.E.I AUSTRALIA
XRAY*****PRO-LINE*****HUDY*****
-----FUTABA-----NOVAROSSI-----
aussies1129 is offline   Reply With Quote
Old 03-08-2009, 03:13 PM   #3876
grub's Avatar
cheers
gidday aussie
just clean the one way bearing with brake cleaner
and put one drop of xray one way bearing lube on it will be good a s new .
This is my xray nt1!
There are many other xray nt1's like it, but this one is mine!
Without my xray nt1,I am nothing!
Without me, my xray nt1 is nothing!
pop corn anyone or maybe some fairy floss
grub is offline   Reply With Quote
Old 03-09-2009, 02:05 AM   #3877
Originally Posted by grub View Post
gidday aussie
hey cheers mate I will give it a go cant work out why it started to slip anyway thanks for the advise. are you running lipos in your car if so what do you think about xrays new lipo brass battery plate?
cheers
H.E.I AUSTRALIA
Old 03-09-2009, 02:12 AM   #3878
Heard the factory one don't last long. Sorry I got a used NT1 with a red gear hub and not sure who makes it so I am not sure how the factory one will hold up. All my friends are using the red one and I am still using the red one I got with the car and had around 50 runs on mine and it is holding up well.
ehirobo
cheers
ehirobo.com is offline   Reply With Quote
Old 03-09-2009, 03:15 AM   #3879
grub's Avatar
cheers
hi m8
some times fuel gets spilt on first gear and chases it to slip ..
when you took the first gear off was there oil on the shaft?
yes im using the ybslow battery tray and chassis weights
with my vmx 1300 lipo battery i put the extra 35 gram weights on the exhause side to balance up the car
i found the tray an weights settled the car down heaps you can also come in to the corners a little bit hotter
Old 03-09-2009, 03:35 AM   #3880
grub's Avatar
ehirobo
3 racing lightened shaft and hub are red
Old 03-09-2009, 05:22 AM   #3881
hi m8
yep sounds good thats the way to go cheers for that!
H.E.I AUSTRALIA
Old 03-09-2009, 07:44 PM   #3882
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
are you talking about serpents new or old springs? cause the new serpent red is stiffer in the rear than light purple(looks pink), and blue front is even stiffer than light purple.. will recheck tonight but thats what I remember rating them as when I checked them a couple weeks ago.
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 03-09-2009, 10:56 PM   #3883
Thanks man! Ask my friend last night and he told me they are 3 racing one. I am using light purple (look pink) up front and purple at the rear on high grip track we race on. For dusty parking lot I usually use purple up front with light purple or purple at the back.
Old 03-10-2009, 11:34 AM   #3884
O sorry forgot to mention, this is with the old springs, never used the new one's.
Had the old one's laying around from my 710-720 days.
Btw, did anyone tried lowering the engine?. I think it's pretty easy to lower it by 1mm, because i'm currently running the serpent WC clutch with the small flywheel and it's pretty hard to get the starter wheel to grab the flywheel.
I would only like to know if you will run into issues with the stock flywheel i.e. hitting the ground.
P1-RC.com
Old 03-10-2009, 05:29 PM   #3885
rx7ttlm's Avatar
if you had the inclination you could lower the engine 1mm or so by milling the bottom of the lower engine mounts.
