Mugen MBX6
throttle
http://www.amainhobbies.com/product_...rion-Savox-ACE
steering
http://www.amainhobbies.com/product_...taba-Orion-ACE
the hudy horns are a tight fit on most servos..i use them on Savox but they look the part and are super strong.
I have always used these Hudy ones..i fact..still my first set lol
throttle
steering
throttle
steering
Thanks Sideshow!!
hey dudes, this dynamite throttle linkage is awlsome, thanks slideshow.
rear setup??
does anyone have a rear setup suggestion,
on my mbx6 +5chassis i am running forward battery I think I have 10-7-3 and 35 weight and ride height 30r28f in the rear the car is fast but is very twithcy in the rear I am fighting it all the time one small bump and it upsets the car always, its feels as if the back of the car is to light? as it jumps around alot if anyone has a good setup for the rear to settle the car down that would be great as i am sure the car can go alot quicker if it settles down
cheers
cheers
cheers
cheers
cheers
cheers
makes the car too twitchy, that might be good for the first 10 or so minutes of a main but after that mental fatigue can start setting in and a twitchy car can make for a horrible time because it can be so difficult to drive fast.
Vic Slider Fernald MBX6R 2012.pdf
cheers
cheers
cheers
cheers
Regarding fuel tank issues and previous changes in post 17288.
Well after trying all of those steps to fix the fuel tank issue, it was still there. Just to test it, I even changed different engines again. This is just odd as both engines, once warmed up, will run great but as soon as I fill it back up from almost being empty, then it richens up dramatically and usually flames out.
Even after we restart motor and get it running then it takes a good 10-15 seconds of blurping and almost flooring it to get to stay running and then finally be able to race again out of pit lane.
Now here is something odd. After that I was again a little pissed off. I tore off all of the fuel lines with the excess runs and then I ran a very short pressure line from pipe to gas (seriously short) plus my normal short fuel line run to carb. Mounted back on my O.S. Speed motor and it fired right up wth no odd idling and during the A-Main pit stops there ws no flameout issue. Hmmm.
So could it be the Werks B6 Pro and Mugen JX21 both have issues and O.S. speed was fine? About to go crazy (well more then normal, LOL).
After seeing much discussion about a fuel tank clunk mod, I do not see how that would resolve pit lane flame out issue, as I can flip over and my engine will idle fine without flaming out or leaning out (easily 15-20 seonds), using normal tank with no clunk. Regardng the flame out in the pits how would the fuel tank clunk mod really help at all on that issue?
My buggy was doing the exact same thing with an Alpha F-850 on it. When that motor was in my RC8.2 I never had a single flame out. Very strange and I guess a sign of things to come.
Can someone tell me the inner bore size of the shock body and outer diameter of the piston
Has anyone used this air filter oil?
http://www.amainhobbies.com/product_...r-Fluid-SWWAFF
