Mugen MBX6
has anyone done any in depth testing with the csi pistons? i have the black ones in my car, just curious if anyone has found anything while using them, i havent had time to run my car in the last 2+ months.
So I didnt get to make it to the JBRL last weekend but I will be out at Rev this Sat for the Agama race. I know I posted a setup on here and wanted to see how people liked it that raced the JBRL and what adjustment people made if any.
As far as SCI pistons I have never tried them but the new Mugen tapered pistons work great and I am running them in all my cars
I've got the v1 blacks with 45 f and 35 rear losi oil with the black 9.25 springs in the front and 10.0 black in the rear and absolutely love it. I'm thinking about trying the v1 blues with Thoes springs at the next club race. If you got any questions let me know.
Those changes made the car much more predictable especially as the track came apart.
I am trying to get out this weekend for the Agama race and plan on running the same setup.
Kev, I ran you're setup last weekend at the JBRL. On Friday I found the car to be a little a$$ happy and pushy. The suspension was dialed. Here are the changes I made to you're setup. Changed the front diff to 5K and the Center to 7K. Changed the clutch to a Works with 2 Carbon/.9 and 2 Alum/1.0.
I was able to drive hard in to the turn get off the gas and turn then back on gas. on parts of the track we had. some parts I was able to line up much faster than I was before
you said pushy going to the turn? and a$$ happy to. that's a crazy combo.
I want to underdrive the rear of the car so do I put options gears in the back diff?
Also wouldn't the alloy act as a heat sink drawing heat out of the diff and help the cooling ? The plastic diff case wont absorb any heat so the heat in the diff has no where to go. At least with the alloy one the heat has somewhere to go and because of the extra surface area can dissipate the heat more efficiently.
They make cooling heads for our engines out of alloy. Not plastic.
Timox, i've never heard of anyone stripping so many centre mounts, just loosen your grip and use your fingers when tightening up screws into plastic so you'll feel when they're getting tight, are you having this problem with other parts of the car?
Keep stripping the 4 long screws that hold the diff mount together. Stripped about 4 diff mounts now. So was looking for something a bit more bullet proof.
They don't ever seem to feel like they are getting tight the screws just seem to slip in the plastic real easy. They could do with a bit longer screws so they have a bit more to hold into. Its only like the last 4 or 5 threads that are actually screwed into anything.
Just a quick question.
Would someone be kind enough to tell me how many "R" versions of the kit there are, and what are the differences between the versions?
John as far as I know the only R now is the new USA spec buggy. I think all the old R cars are gone. As far as whats diff between the 2 R cars. Its just a bunch of alum upgrade parts and all the carbon is now silver.
