Mugen MBX6
Mike S. is the man! He's actually the one who convinced me to give the Mugen a try.
What bearings are you guys using on wheels and diff? We run in extremely dusty conditions. Also what is the best way to maintain bearings? Paint thinner clean?
Has anyone had a problem with the NOVA 4-C team in the Mugen? The housing for the high speed needle sticks out so far that its hard to even get the body on. The housing pushes against the left window really bad. So bad that on my practice body,where I drilled a hole in the window for screwdriver access, the whole top of the needle housing actually sticks out of the hole. Easy access for sure but I definitelly dont like it exposed to the elements like that. On the race body(no hole drilled yet), its so tight that its only a matter of time before the body rips either at the post holes or the housing digs straight through the window. I thought about trying to heat it up and bow out the plastic to relieve it a little, kind of janky though.
Somebody has to have experienced this right??
I use agama shock boots. They are thick and last a very long time. Been using the same ones for probably 6 months.
This setup is extremely good at Revs.
Sweet! I forgot to mention that I am running the new pistons MUGE0580
Thanks Megasaxon, I guess I'll just run it.
SEF and Kthatcher, im going to hit you guys up if thats ok. Probabally going to be heading to Rev as much as possible in the next few weeks to get ready for JBRL. Could use all the help I can get with getting the Mugen setup right.
Hey Kevin, why the high diff oils I always at rev ren around 5,7,2.... Im ganna run this set up for rev since i haven't got much time on my R this year only jbrl really so if you feel its dialed im trusting you lol. Go ahead and pm me or what ever, you also gave me ur number but i think i lost it. I will look in my pm's. thanks and see you out there on the 12th?
springs? Black 9.5 front and 10.5 rear. Battle used 9.75 and 10.75 at neo, I started off with battles spring setup. It was a little on the soft side, so I went to the 9.5 front and 10.5 rear and was able to drive the car a little harder. Thats all ive ran so far, need to try what the US drivers liked when they used black springs. But the 9.5 and 10.5 was good at silver state and a couple days ago at hot rods
I keep testing and trying out new things every time I'm out there for practice.
I might be there Thursday if I'm lucky.
[QUOTE=chad bradley;10663919]I started off with the standard (grey) oring at the top, and low friction (black) oring on the bottom. it worked good, very free and no leaking (u have to have a 1.5mm spacer between the orings, stock spacer is only 1mm). Since I noticed no leaking I wanted to try all low friction orings. super free the shock body almost slides on the shock shaft with its own weight. I ran my car in two qualifiers and after checked to see any leaking, none of the shocks leaked, however on one of my shocks air mixed in with the oil (wasnt enough to be a concern)
I would have both types of orings on hand[f/QUOTE]
Video from last friday nights club race
http://www.youtube.com/watch?v=d2OjQCAyZVg
Ran basically my Silver State setup (just limited the droop) and put back on the long front brace, forgot to mention I used the shorty plastic front brace at Silver State for the bumps. Limited my droop back to 108f and 128r. I also tried "super" active caster (high hole insert on the mount and low hole insert on the front tower for the upper front arm). I think it might be a little too much turn in, but its a good thing to remember to try for Indoor stuff (electric or nitro) if you want a mad amount of turn in.
