Like Tree3Likes
Mugen MBX6
Old 11-10-2008, 12:22 PM
  #1381
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
yeh every m00g i've seen has duck feet. if you have pigeon toes, there is somethin wrong or you running an ofna lol
R
UltegraSTI is offline
Old 11-10-2008, 12:47 PM
  #1382
Default mugen
thanks guys
since i am not very experinced, how many milimetres from the top pillow ball to the top upper arm? am not sure about camber lenght and stuff
muaythai is offline
Old 11-10-2008, 02:12 PM
  #1383
blazinb's Avatar
on my setup station that 22.5mm adjustment for the steering links was out to lunch. for around 1 degree toe out i think it's like 25-26mm
blazinb is offline
Old 11-10-2008, 03:31 PM
  #1384
tony montana's Avatar
Trader Rating: 76 (100%+)
you are right about that. Mine were way off. The ackerman was hitting my front upper arms, but after I adjusted the droop it was ok. So the stock setup is bouncy? What are you guys doing to correct it? I just hope there arent gonna be alot of problems with my x6. I just hope it will be a tank like the mbx5r
tony montana is offline
Old 11-10-2008, 03:42 PM
  #1385
Muaythai, having just measured my steering turnbuckles they are 25.6mm in between ends, this gives me precisely 1 degree of toe out with 2 degrees of negative camber, verified by setup station. The upper pivotball distance between wishbone and hub aswell, is measured at 3.8mm. This should be a relatively good starting point, but fine tuning will likely be necessary
Ashalak is offline
Old 11-10-2008, 03:49 PM
  #1386
ok so 3.8mm for the top piviotball? and 25.6mm for the front turnbuckles?
Old 11-10-2008, 03:58 PM
  #1387
allan42r's Avatar
super simple guys, as per your directions the lower pillow ball( this is the one with a shoulder on it) gets one spacer on it and then screw it all the way into the lower a arm. the camber is then adjusted with the upper pillow ball.
allan42r is offline
Old 11-10-2008, 06:18 PM
  #1388
mp3ranger's Avatar
Trader Rating: 19 (100%+)
What do you think about this RX lipo battery ?
Length: 3.3" (84mm)
Width: 1.1" (31mm)
Thickness: 0.63" (16mm)
http://www3.towerhobbies.com/cgi-bin...1559&search=Go
mp3ranger is offline
Old 11-10-2008, 06:19 PM
  #1389
Trader Rating: 18 (100%+)
Actually I didnt break the outdrive pin as I had thought. This is what happened instead.
infanterene is offline
Old 11-10-2008, 06:25 PM
  #1390
Crap pics too big to upload.
My outdrive broke where the pin goes through. I wish mugen would use the standard(bigger) out drive shaft.
Old 11-10-2008, 06:47 PM
  #1391
What li-po battery pack will fit and what li-po battery regulator?
revracer222 is offline
Old 11-10-2008, 06:59 PM
  #1392
Integrated's Avatar
the Protek 2300ma 7.4v Lipo fits snug and i use the VXR Racing LVR-5000 Regulator, below is a pic of my setup, i also run the VXR Racing Battery Indicator (LBI-0023)
Integrated is offline
Old 11-10-2008, 07:07 PM
  #1393
would this regulator work with that battery? and do i need a switch?
http://www.amainhobbies.com/product_...oducts_id/4787
Old 11-10-2008, 07:11 PM
  #1394
I dont recommend that one. I burned out 2 of them. The switch is garbage and needs to be changed out before use. Also its only rated for 3 amps and I think you need atleast 5 but 7 is better.
Old 11-10-2008, 07:14 PM
  #1395
where can you buy the VRX stuff at?
