Like Tree255Likes
Tamiya TRF419
Old 08-05-2019, 08:09 PM
  #4411
Raman's Avatar
Trader Rating: 94 (100%+)
Good bit of information
Raman is offline
Old 08-06-2019, 03:51 AM
  #4412
Tom1977's Avatar
Default New suspension mounts
For testing purpose!
But I think, I will equip my 07MS with them.
For my 419XR I have already all old style blocks, therefore 07MS makes more sense.
I'm courious if the new suspension can convince me...
walrusjon likes this.
Tom1977 is offline
Old 08-06-2019, 06:05 AM
  #4413
Tom1977's Avatar
Installed the items on my TA07MS.
For TRF419XR it's the same...
I wanted a more narrow track width in the rear, so I decided for XB-XB-Blocks. I realized a 0.5 degrees rear toe in with N2/N1 inserts. Most of you will went with A-A blocks in the rear...
Inserts are snug and you have eventually readjust your wheelbase with your spacers. I flipped the 1.0mm to the rear and due to tighter tolerances I removed the 0.5mm shim from axles.
Weight is nearly the same. The seperate blocks are the same, the mono block is slightly lighter.
To achieve a 2.5 degrees overall toe in, I decided for the new 2.0 degrees aluminium uprights. This gives me the chance to set 2.0 or 3.0 overall toe in via inserts.
You add approx. 3 grams with this uprights. Tolerances are very good.
On front I will go with 0.5 C-C which I will realize with A-A blocks and N6/N6 inserts. Parts will arrive tomorrow...
Overall - it's not a must have, but a may have hop up. Especially if you already have all old blocks for your racer, it's not necessary to update.
P.S. in picture #5 I realized that the XB-monoblock was mounted wrong. I flipped it (markings to the arms) and added the 0.5mm spacer again.
Tom1977 is offline
Old 08-07-2019, 06:19 PM
  #4414
snopro31's Avatar
Trader Rating: 57 (100%+)
For anyone that is considering swapping to the alloy gear diff case from plastic
it’s only a 2.4 gram difference between the alloy and plastic.
No anyone that has run the alloy did you really notice a difference on the leaking?
And if you did was it with the alloy pulls as well?
as with a day of testing I found my alloy with plastic pulley wasn’t really any better maybe I did something wrong?
snopro31 is offline
Old 08-07-2019, 06:30 PM
  #4415
Tom1977's Avatar
I run full aluminium. No leaks.
Tom1977 is offline
Old 08-07-2019, 07:53 PM
  #4416
rc_square24's Avatar
In my experience, leakage only happened at the outdrives and not between the case and pulley, whether its plastic or aluminum. Ive tried changing the amount of fluid I fill but they still leaked. Once I changed to xray 972050 orings it stopped the leak. They're a bit larger so has more drag but is leak free.
I think the diameter of the oring recess on the TRF419 diff cases are a bit too large for the Tamiya red orings. Even with the outdrive inserted, the outer edge of the oring just barely touches the wall of the recess. The depth of the recess is also greater than the thickness of the oring, so adding shims won't compress the oring to make a better seal.
IMO the aluminum diff case helps dissipate heat to keep the fluids more consistent and doesn't fix leakage if that's your problem. With the plastic diff cases I always sand the seating surface for the gasket to make sure its flat. The gasket is quite thick so maybe the sanding is not necessary, but I haven't had any leakage in between the case halves.
I ordered some Axon black and clear orings to test if they provide a good seal with less resistance than the xrays. Will report back the results.
rc_square24 is offline
Old 08-08-2019, 02:35 AM
  #4417
Tom1977's Avatar
Tamiya #42313 (TRF large shim set)may help with leaking on the out drives. Shims are larger as kit ones and pressure on o-rings is more equally distributed.
Tom1977 is offline
Old 08-08-2019, 06:15 PM
  #4418
snopro31's Avatar
I am running the axon clear orings , they work well I did not switch diff cases for leakage the plastic ones leaked so very little it wasn't an issue but the new alloy leaks about the same so I was just asking if anyone had similar results. because if someone has zero leaks I want zero leaks lol.
your in Vancouver can I ask your name? or your initials I think they are T.T as we hit a lot of races in bc would be nice to put a face to you I assume you race at rrr or overgeared? IF your initials are T..T I am rob I have met you a few times I think we even did some Tamiya parts swapping at the big chill a few years ago when Ivan was there with you
snopro31 is offline
Old 08-08-2019, 06:29 PM
  #4419
snopro31's Avatar
Are you using stock orings or some other orings?
snopro31 is offline
Old 08-09-2019, 01:02 AM
  #4420
Tom1977's Avatar
I use the red orings and TRF VG gear diff grease (#42212). I apply it in the out drive holes and on oring. You can also lay in a 0.2-0.3mm shim into the recess area of oring to increase pressure on it.
Tom1977 is offline
Old 08-09-2019, 04:43 AM
  #4421
JoeyE's Avatar
Trader Rating: 45 (100%+)
Any company making a mid motor conversion for the TRF419XR?
JoeyE is offline
Old 08-09-2019, 12:55 PM
  #4422
team green's Avatar
Trader Rating: 14 (100%+)
team green is offline
Old 08-09-2019, 01:01 PM
  #4423
snopro31's Avatar
Hmm to me that says let’s sell these quick before the new car is announced lol
really hope I’m right!
snopro31 is offline
Old 08-09-2019, 01:40 PM
  #4424
Tom1977's Avatar
I think not before late autumn/winter. The 419 is in its 3rd year, time for TRF420.
375 is incredible price!
hanulec likes this.
Tom1977 is offline
Old 08-09-2019, 02:06 PM
  #4425
Raman's Avatar
yep.. new car will be announced this fall.
now if they only would put a sale on the XR Aluminium chassis
Raman is offline
