Tamiya TRF419
#4566
Regional Moderator
with out reading the last few pages is there a better diff then the stock one 419x? if not what seals are you guys using?
on my diff i found the cross pins bent. so i used the white cross seems ok but the leaking out the drives suck
#4569
#4570
This post here may help with the leak. The 420 diff is lighter but assembly is key for a leak free diff whether it be 419 or 420. By the cross pins you mean the aluminum pins/shafts that hold the four small bevel gears? It is quite rare to have them bent, a picture could help determine the cause.
#4571
#4572
#4573
Finally switched over to the 420 arms. For the front CVD, you still need to use the narrower 3mm bearing..I think the 420 has a longer shaft, that’s why you can use the 4mm.
I have quite a few new / unused 419X front / rear arms. If any needs some please let me know, will gladly share for cost of postage!
#4574
9803222)
#4575
The axles are now released under 42363 - Axle Shafts for TRF420 Double Cardan Joint Shafts (2pcs.)
