Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 06-11-2022 | 04:02 AM
  #3301
Originally Posted by Monsta
Hey TurboThirdGen, The bottom of the body is the same height as the chassis!
Also, i cant see the diffuser on Thingiverse. could you please give the link directly for it?
Cheers
I've got a few more tweaks to the diffuser to make sure it doesn't rub the inside of the body before I upload it.
Same height of the chassis, so below the bottom of the front bumper assembly? Any way for you to get a rough MM measurement?
One splitter I have is to be mounted right up against the bottom of the bumper assembly, The reason I ask is I have another version about 3-4mm below the bumper assembly, So I want to make sure it'll fit yours too.
Had to work the last few days. I should be able to upload these on Monday after printing the next versions for test fit. The splitters just need a height modification, the diffuser needs the outside perimeter modified to better fit the body, but they are super close. Work just got in the way.
-RC Perspective
TurboThirdGen is offline
Old 06-11-2022 | 08:59 PM
  #3302
Monsta's Avatar
Yep, the body sits lower. It has 11mm clearance to the ground.
Ive printer the splitter you have up and like its height. it does sit higher than the bottom of the body but therres enough flex between it and the body for a nice seal. Plus it allows for full compression without bottoming out.
gwhiz and TurboThirdGen like this.
Monsta is offline
Old 06-12-2022 | 05:01 AM
  #3303
Perfect! I'll make note and make a version about the same height as that generic splitter and hopefully have it uploaded for you tomorrow!
A some point I'll make a variation of the side skirts for the Porsche bodies.
Did you use the Audi skirts or the Evo skirts?
Old 06-12-2022 | 06:35 AM
  #3304
Default TT02 1973 911 Carrera RSR Front Splitter
Cheers
Figured I'd let you know I uploaded a Splitter for the RSR. When you have a chance let me know how it fits. It should be about the same height as the round nose one you used.
https://www.thingiverse.com/thing:5409193
I want to make sure the diffuser fits better with the modifications I've made. I'll be printing one today or tomorrow to test fit and will upload shortly after.
-RC Perspective
Old 06-15-2022 | 04:57 AM
  #3305
-RC Perspective
The link seems to be 404
F1jet_ is offline
Old 06-15-2022 | 05:03 AM
  #3306
The link works for me.
Try this one if it doesn't work for you. https://www.thingiverse.com/rc_perspective/designs
That'll bring you to my collection of designs.
Old 06-15-2022 | 05:35 AM
  #3307
Monsta's Avatar
Hi @TurboThirdGen, i get a "page not found" when clicking the link
Monsta is offline
Old 06-15-2022 | 05:38 AM
  #3308
gigaplex's Avatar
You mentioned you're racing this. Have you checked if the splitter is legal? Most rulesets forbid solid bumpers from protruding outside of the body (safety measure to protect the marshal's ankles), which this splitter would qualify as.
gigaplex is offline
Old 06-15-2022 | 07:49 AM
  #3309
Sometimes Thingiverse doesn't work as it should. I've deleted it and re-uploaded it. Give this one a try - https://www.thingiverse.com/thing:5411611
Old 06-20-2022 | 02:26 PM
  #3310
Dan's Avatar
Dan
I can't wait for this body to be released.
Raman, Qatmix and angrymelon like this.
Dan is offline
Old 06-20-2022 | 04:21 PM
  #3311
I wish they would have made a third gen (82-92) Camaro body.
The only ones that are out there don't look right and also don't fit on a TT02
Old 06-20-2022 | 08:36 PM
  #3312
Raman's Avatar
Light weight version for TCS!
Raman is offline
Old 06-20-2022 | 08:38 PM
  #3313
Raman's Avatar
OMG.. you’re an 911 RSR fan and like 82-92 Camaros. How can this be? Those Camaros put the series in its grave for a decade. Only Camaros I can tolerate are gen 1.
Raman is offline
Old 06-21-2022 | 04:16 AM
  #3314
Correction, the Catfish 93-02 fourth gen Camaros put the name in the grave.
The Third gens were on rails! Out-handled the Porsches, Lambos and Ferraris from that era.
Also took design cues from the Ferrari F40.
Best car I ever had. Still have, 14 years later. Cummins Turbo; 21psi of boost on a stock v6! (I built the wiring harness and ECM from scratch. Built the transmission and rear end, lowered it and did suspension work. Built the whole turbo setup myself, full 3 inch single exhaust from the turbo back). I couldn't afford a first gen, this was my first car. Mine is the red and black one. I'm a sucker for these lines.
Holset HX35W Turbo
Ditched the distributor and went with triple coil pack DIS ignition
Just something about those lines. Red one next to mine has an LS6 with an LSX supercharger, Purple one is also an LS, with a Magnussen supercharger
Plus, who can forget about Knight Rider? That was a Trans-Am; but same decade and bodystyle.
One day mine will have an all aluminum 5.7 LS truck engine and a T56 manual transmission. The entire aluminum LS weighs less than the cast iron v6!
Old 06-21-2022 | 04:42 AM
  #3315
Hey bubba, let me know if that new link works. It seems to come up in a search for TT02 parts. It's the updated splitter for the RSR.
I've got some time today, So I'm gonna print out the updated diffuser, and if it's good I'll have it up later today.
Decided to give the 3d printer some rest. It's been going non-stop for a month haha
