Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 06-20-2020 | 02:27 PM
  #2551
liljohn1064's Avatar
Originally Posted by JJ100179
I just revisited thercracer site and checked the article.
The author mentioned a ride height of 5mm front and 5,2mm rear, but not how these are achieved. He is using the 42102 TRF shocks, but no indication which spring or other settings are needed to get there. So, maybe you are kind of misguided at the moment?
I had to use internal stops with the CVAs. I used an o ring on the fronts and the 2mm spacer from the shock parts tree to get where I wanted.
liljohn1064 is offline
Old 06-26-2020 | 11:45 AM
  #2552
Hoyle33's Avatar
Has anyone seen that Tamiya is selling these Mercedes CLK TT-01E kits again?
$115 is hard to beat
https://www.amainhobbies.com/tamiya-...47437/p1172162
Hoyle33 is offline
Old 06-26-2020 | 06:59 PM
  #2553
Kremzeek's Avatar
I just want the body.
Kremzeek is offline
Old 06-27-2020 | 05:34 PM
  #2554
Out in the parking lot playing around. The car likes to swap ends under acceleration. I would like to get more rear droop but the springs are too stiff. I set ride height and preload and get maybe 1 to 1.5 mm of rear droop. I'm running yellow fronts, kit rears. The beige springs seem softer than the reds. Ride height is 5.5 all around. I'm running internal stops in the shocks and the shimming preload with the spring spacers. If I take out the shims, I'm left with slop. I'd really like to find a longer, softer spring to allow more droop. Do I have to go aftermarket or is the a set of soft springs that works with the CVA shocks? I'm sticking with the CVA set as they are TCS legal for the class I plan to run.
Old 06-27-2020 | 08:52 PM
  #2555
Kremzeek's Avatar
I'm running the reds on the rear of mine. How many spacers do you have in your shocks?
Kremzeek is offline
Old 06-28-2020 | 12:15 AM
  #2556
I used to have 29mm springs in the CVA shocks of my TB-03. They are long enough to be installed without spacers.
MST 29mm springs
They are sold in pairs or in Sets of 8 springs. Maybe Set 820113 can be a good starting point for you: 820113 (buut no guarantee that they will have your needed characteristics)
liljohn1064 likes this.
JJ100179 is offline
Old 06-28-2020 | 04:50 PM
  #2557
liljohn1064 Have you tried the kit springs in the front and yellow in rear? Or yellow (that come with the CVAs) all around? I think those silver kit springs are stiffer than the yellow springs, which is going to make the car tail-happy.
Even with balanced springs (yellow) all around, I find it's relatively easy to get out of shape putting power down coming out of a corner. I suspect that the kit tires have a lot to do with it too.
OTOH, with only a torque tuned motor, changing to super sticky tires will eliminate any drama involved in driving this thing.
SennaPK is offline
Old 06-28-2020 | 05:44 PM
  #2558
I completely agree. The kit springs are the softest. I have the hard set yellow on the front. They will come off. I ordered some Sweep 32 and 36 sets, both J type, the asphalt designation. I'm hoping for some better results.
Old 06-29-2020 | 10:59 AM
  #2559
So I'm currently building the Tamiya TT02 universal shafts ... I machined this aluminum ring and attached to each universal wheel axle with some superglue. To capture the cross joint's pin and prevent it from coming loose.
TheOtherBill and Kremzeek like this.
userst is offline
Old 06-29-2020 | 12:57 PM
  #2560
Also tried something new here ... rubber cover on the universal joint to keep grease in and dirt out. I cut about 1" off the ends of Qualatex 260Q balloons to make these.
angrymelon and tomthegeek like this.
userst is offline
Old 07-01-2020 | 10:23 AM
  #2561
I bought the SkyRC GSM020 GPS a while back ... I wanted to track how fast the TT02 can go with a 19 turn, hand-wound brushed motor and 7.2v Ni-MH battery. Yesterday I changed to a 29T pinion and 55T spur gear (4.931 FDR) and put some advanced timing to the motor ... today it tops out at 37mph. Not bad.
The stock TBLE-02S ESC couldn't handle the motor anymore at this gear ratio though. I swapped it out with a Hobbywing QuicRun 1080 and it's working OK so far.
userst is offline
Old 07-01-2020 | 10:43 AM
  #2562
How do you take it apart in case of a damage or a needed repair?
JJ100179 is offline
Old 07-01-2020 | 10:58 AM
  #2563
Yeah I'd probably have to knock it loose with a hammer when that time comes. More ideal solution would've been to use a removable ring locked onto a groove on the shaft's outer diameter.
userst is offline
Old 07-01-2020 | 11:00 AM
  #2564
eR1c's Avatar
Also considering it comes w/ the ESC and a Motor, it is a GREAT deal, ...yet I have enough cars so as tempting as it is ...
angrymelon likes this.
eR1c is offline
Old 07-02-2020 | 01:16 PM
  #2565
after one year not using my tt02s I upgrade the adjustable suspension block from the rear SR and the new aluminium steering... tomorrow I shorten the body posts and setup and race this weekend! I will see if it make the car better or worst
Sukram is offline
