Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 05-25-2022 | 07:51 AM
  #3286
Finally got a few good snaps of the Carrera at dusk.
OVA, Raman, Qatmix and 2 others like this.
TurboThirdGen is offline
Old 05-26-2022 | 09:09 AM
  #3287
Originally Posted by GerryH
I'm pretty sure the TBLE-02 comes with the TT02 kits, so it's probably the most common in that class. People have commented that the battery cutoff voltage is too low for lipos because it's calibrated for LiFE batteries. But you can probably run this car on a 5000-6000mah battery for over 30 mins, so it's not an issue when racing.
I'm about to hop on that new Mustang TT-02 they released, need something to putz around in the parking lot. Is the consensus still a 2S lipo? I've been reading the motor gets hot and now the lvc.
I'm also not seeing much of any LiFE batteries anymore.
What's everyone running? Type and mah?
TIA!
Evoking1230 is offline
Old 05-26-2022 | 09:51 AM
  #3288
TIA!
A 2S lipo will be fine and fits perfect and works with the included motor and ESC. You can change the gearing if more speed is needed at a later date inexpensively.
angrymelon and Evoking1230 like this.
SteveM is offline
Old 05-26-2022 | 10:54 AM
  #3289
Ooof
What mah you running?
Old 05-26-2022 | 11:43 AM
  #3290
Ooof
I use Goldbat 2S-5000mah packs with an 80C rating I purchased cheap off Amazon. Each came with the charge lead, a Traxxas adapter, and a Velcro strap. I've used these in all my R/C cars and they've been extremely reliable and zero issues. No puffing either.
Evoking1230 likes this.
SteveM is offline
Old 05-27-2022 | 10:14 AM
  #3291
sweet, thanks for that. The wife will appreciate the lower cost of this build
Old 06-02-2022 | 05:42 AM
  #3292
I've been working on the prototype splitter and diffuser for the 911 RSR body. Second prototype of the splitter and first prototype of the diffuser. Had to come up with a mounting system for the diffuser that allows the use of the rear bumper assembly, as I use the bumper mounted body posts all the way around. The mounting system came out excellent, and with a few more added tweaks it should work perfectly!
Here is a couple preview pics. I need to tweak the diffuser to come down a little more to be about flush with the bottom of the body. And I may add a slight curve on the splitter to more match the curve of the nose in the center.
Splitter
Diffuser
This stuff will be posted up soon once I finalize the designs.
As a reminder, My 3D print files are free and you can find them here: https://www.thingiverse.com/rc_perspective/designs
PS - Sorry for the poor photo quality. My Pixel 3XL bricked randomly overnight a couple weeks ago and I've had to downgrade as I don't have the funds to get another Pixel. This new phone has a "pro" camera mode, which is sadly more miss than hit.
Qatmix likes this.
Old 06-02-2022 | 04:40 PM
  #3293
[QUOTE=Qatmix;11835527]The thing is its designed to be what it is with the expertise of one of the leading RC brands in the business. Its an all round chassis that will be a great base to start with in Onroad RC. It can race, drift and rally and most importantly, it will be reliable and strong. Its not going to compete with a sakura S or Spec-R S1, but out of all of the 3 chassis, the TT02 would be the last one to break.
Case in point to the ruggedness and price point: the TT02T.
The TT02T, Tamiya p/n 58608, was just a stadium truck body and larger off-road wheels bolted onto a TT02 chassis.
Long since sold out and now discontinued.
F1jet_ is offline
Old 06-02-2022 | 04:50 PM
  #3294
Default .
[QUOTE=F1jet_;15909192]
And Tamiya did this before - the TA02T was an inexpensive tub with pickup bodies, big wheels and tires.
It was designed for the backyard Baja 500 and was cheap and fun to drive.
F1jet_ is offline
Old 06-02-2022 | 04:56 PM
  #3295
Default .
And Tamiya did this before - the TA02T? Released in 1994! An inexpensive tub with pickup bodies, big wheels and tires.
F1jet_ is offline
Old 06-06-2022 | 06:01 PM
  #3296
Monsta's Avatar
Splitter
Diffuser
Beautiful! i'll be printing them up for sure! thanks
Monsta is offline
Old 06-07-2022 | 05:22 AM
  #3297
I've mad a few small tweaks to the splitter, and have been playing around with the mounting system for the rear diffuser. Look for an upload in the next few days!
Question for those running the 911 RSR Carrera body; What is your body height in relation to the chassis? Is it close to the bottom of the chassis or just above by a few mm?
I'm asking cause currently I have the splitter height right up against the bottom of the front bumper assembly with no spacing. I figure most of you have the body about the same height, but just want to make sure. There is no way to go higher with the splitter, but it can go lower.
I have added a slight curve to the front of the splitter to help it flow better with the curve of the front bumper.
And I have modified the mounting height of the rear diffuser. The diffuser will take a little more tweaking to make sure it fits well and doesn't bind on the back of the body like it currently does.
As you can see, in line with the diffuser I made for the 1991 Audi V8, I've been building the diffusers with a spot to mount exhaust pipes on it instead of the body. Which not only seems to look more authentic, but also alleviates figuring out how to mount it to the body. Though its not terribly difficult at all, cause I've done it too.
-RC Perspective
Let me know how you like the changes to the splitter! And feedback is also welcome for the diffuser!
Old 06-07-2022 | 05:27 AM
  #3298
Also, Is it OK to post links to my build threads on Tamiyaclub? I figured I'd throw my build threads on there first. I will eventually add them here, but I've been building them up over there first.
Old 06-07-2022 | 05:32 PM
  #3299
Monsta's Avatar
ill try to get a measurement tonight, but this is the height i race at.
Monsta is offline
Old 06-10-2022 | 08:56 PM
  #3300
Monsta's Avatar
Hey TurboThirdGen, The bottom of the body is the same height as the chassis!
Also, i cant see the diffuser on Thingiverse. could you please give the link directly for it?
Cheers
Monsta is offline
