Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 04-29-2022 | 09:37 PM
  #3256
Vertebreaker's Avatar
Originally Posted by Raman
So you allowed non Tamiya bodies, so long as they were non TC?
Yep, we could run whatever brand we wanted. I was running a 2010 Challenger body. But that's what I mean, each club is going to have their own variation to the rules because many times with a class like that they want to keep things fairly level, cheap, and fun.
Vertebreaker is offline
Old 04-30-2022 | 04:13 PM
  #3257
Raman's Avatar
cheap is a perception and relative. They used the same argument for USGT, now the class is dominated by look a like bodies of hyper cars for $39, vs $42 for license Tamiya bodies. We’re all asking each other.. hey is that a Ferrari, no it’s an Aston, really, it looks like a Lamborghini to me 🤦🏻
Im pushing for GT ProSpec per Tamiya rules at our next big event at 702 on May 28. Keeping it scale
angrymelon and JeffofSpace like this.
Raman is offline
Old 04-30-2022 | 07:25 PM
  #3258
Did anybody test tamiya scale bodies vs the latest and greatest performance only bodies ??? If so, what was the difference???
bertrandsv87 is offline
Old 04-30-2022 | 07:46 PM
  #3259
cheap is a perception and relative. They used the same argument for USGT, now the class is dominated by look a like bodies of hyper cars for $39, vs $42 for license Tamiya bodies. We’re all asking each other.. he is that a Ferrari, no it’s an Aston, really, it looks like a Lamborghini to me 🤦🏻
Well I meant cheap because there were a handful of people using their old bodies in this class and not buying something new. We had a good mix of bodies out there with maybe only a couple duplicate bodies in the class which was cool. The other problem at the time and maybe still is to a lesser extent, was that it was tough to find bodies and other Tamiya products in stock. I just run bodies that I think look cool.
Old 04-30-2022 | 09:03 PM
  #3260
JeffofSpace's Avatar
We are doing ProSpec here in Seattle strictly by the rules as well (in TCS preparation). Biggest problem people have run into is difficulty in locating the spec Reedy motors. Bodies seem to be easier to find than a month ago.
JeffofSpace is offline
Old 05-01-2022 | 07:44 AM
  #3261
Raman's Avatar
Agree, reedy motor and a hard to come by. Tamiya should address and allow the torque tune as a sub
Raman is offline
Old 05-01-2022 | 09:23 AM
  #3262
Since the motors are now backordered to who knows when, we need an alternative.
Sabin is offline
Old 05-01-2022 | 11:10 AM
  #3263
IndyRC_Racer's Avatar
Recently I did a tear-down & rebuild of a Tamiya TT02 Type-S. During the rebuild I noticed that a couple of the inner hinge pins on the a-arms were bent - Tamiya item# 9805681 (https://www.tamiyausa.com/shop/7-dig...m-shaft-58261/). This is a 3x48.5mm steel shaft that was/is out of stock on the Tamiyausa website.
I could have purchased Tamiya #54634 (https://www.tamiyausa.com/shop/optio...sus-mount-set/), but wanted to find a cheaper option. I also could have made my own part from steel 3mm rod, but I wanted to find a pre-made option. I did a quick internet search and found the exact length I need from ARRMA. Here is a link...
https://www.arrma-rc.com/en/product/.../ARAC5029.html
I was able to find/buy the ARRMA #AR330524 part on Amazon, but I could have purchased them through Tower Hobbies or Horizon Hobby. These were a direct fit, but I haven't had a chance to test their durability in racing.
I hope this information helps as it can sometimes be difficult to find Tamiya parts that don't have a 5-digit part number.
IndyRC_Racer is offline
Old 05-03-2022 | 03:51 PM
  #3264
Speaking of hinge pins does anyone know of a factory Tamiya hop up for the rear hub suspension pins that use a C-clip instead of the screw in type hinge pins?
Autostrada048 is offline
Old 05-03-2022 | 08:26 PM
  #3265
Raman's Avatar
I asked the same question here 😉
Tamiya TT02 Thread
Part number is 54395, out of stock of course
https://www.tamiyausa.com/shop/optio...ion-sus-shaft/
Autostrada048 likes this.
Raman is offline
Old 05-04-2022 | 03:43 PM
  #3266
Default Tamiya double joint shaft
If i want to run the double joint shaft in the front which one or what parts do i need???
if someone is using the ford gt lightweight body what is the weight of it???
arnold1000 is offline
Old 05-05-2022 | 12:56 PM
  #3267
Raman's Avatar
TT02 stock suspension or TypeS?
I posted about this a few pages back. TT02 stock gets a bit tricky
Raman is offline
Old 05-05-2022 | 02:06 PM
  #3268
It's for the stock suspension.
Old 05-05-2022 | 02:14 PM
  #3269
Raman's Avatar
You need the 39mm dcj shaft with the TRF420 front dcj axle.
https://www.tamiyausa.com/shop/optio...-joint-shafts/
You will need to shim the axle as well. Honestly it’s a costly upgrade and you may not reap the benefits.
Raman is offline
Old 05-09-2022 | 08:17 AM
  #3270
Looking into trying to get a TT02 to 100mph...
Let's see how that goes!
TurboThirdGen likes this.
skimax is offline
