Tamiya TT02 Thread
#3151
I think I went overboard on this build I put together for USGT 25.5
I used TRF 419 arms and installed DCJs in the front and CVDs in the rear.
Also the Hiro Seiko kit for the TA07 works great with the TT02
#3155
#3156
I've read about water-dipping motors to wear in the brushes to the comm. But the water is only for the brushes, so I figured why dip the whole thing? Have some syringes I use for precision stuff, so I filled one with RO water, and the other with 99% Isopropanol Alcohol.
I actually compared this to a silver can that I just threw in and ran. The comm on that one is scored and nasssssty. Might try it on that one and post a before and after.
I run it on a single AA, and use Labelle 106 on the bushings. Couple drops of water on the comm and it starts to work its magic. As it starts to drag running voltage down follow with alcohol to clear the worn brush material. Repeat until the brushes are about 90% worn in, final squirt of alcohol followed by compressed air. re-lube bushings and run.
Wow. It feels smoother, maybe even more responsive I'd dare to say. Who knows, but it seems like a strong little motor.
And as for the final comment; Yes, a mess it is.
#3157
The water method is good for original silver can. The torque and sport tune have much softer brushes.. if you submerge them, they will be done for.. just a simple flash or squirt is enough to break them in
#3159
#3161
Definitely a benefit to doing it but what I have read leads me to believe most who attempt it don't do it properly and get bad results.
But with it used widely in the RC scene many years ago says it did something lol.
#3163
I prefer 64P gears and my gearing is 75/51 that gives an FDR of 3.82 and post #3008 shows that I had to mod the stock gear cover to make clearance for the pinion. I later found a local guy who printed me a new cover that I have since installed.
#3165
Yes within 30 seconds of adding the water to the brushes they wore in rather quickly, hence the alternating between water and alcohol.
Regarding brush debris: Submerging the motor in water allows brush debris to be washed away instantly by the churning water inside the motor, whereas applying a few drops of water directly to the brushes just causes the debris to form a grinding paste that stays on the brushes. That's why the brushes broke-in so quickly for you. If it works, it works, but there's a significant risk of the brushes being damaged by so much abrasive material in such a small area.
(source for magnetic flux explanation: John Rob Holmes of Holmes Hobbies LLC)
1386Likes
