Tamiya TT02 Thread
#3122
#3123
Also, the TT02RR diffs only use 2 small bevel gears rather than the 4 that show in your diagram.
#3124
#3127
I have both the TT-01 and TT-02 stock diffs each with a diff locker installed. They are a drop fit and easily fit without any difficulties or issues.
#3128
#3130
I won Tamiya’s instagram giveway and got a brand new TT02 I’m looking to race in blinky 21.5 class and TCS 2022 pro spec with it.
What are some recommended modifications/hop-ups that aren’t in the TCS rules but are important to have in order to be competitive?
also I’m looking for a TT02 Type-S if anyone is looking to sell theirs.
Tamiya 1/10 TT02 SR 4 Wheel Drive Touring Car Chasis
#3131
Yes, I removed the o-ring too. What’s weird is that even if the block fit in place, the outdrive axle won’t even fit in into the locking block. I’m thinking I probably need a different diff housing, outdrives and pins.
#3133
The 420 arms would drop right in. The only issue is if you use the droop screws / down stops. The 418 to 420 do not have drop screws m both sides as the type S arms. So you would have to drill those in yourself
#3135
1387Likes
