Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 04-28-2020 | 02:37 PM
  #2461
I’m building up my TT02 as a rally spec car for use on a fairly bumpy buggy track, I notice tamiya sell the Super Mini CVAs and the Mini CVAs. Does anybody know if the Minis will fit? I’d like to get the bigger shocks on if possible.
Or, if they won’t, is there a taller shock tower available, tamiya or third party?
rk295 is offline
Old 04-28-2020 | 05:31 PM
  #2462
Originally Posted by Raman
Torque tuned motor is plenty capable and has plenty of torque. If you pick up the yeah racing motor mount, high speed gear set, 64 pitch gears (say 78/48) and bring the final drove ratio down to 4, you will notice the Toque tune is plenty fast!
fdr of 4 on a torque tuned will kill it in one or two batteries. I killed 3 of them in one race day and that was at 4.2. The car went like a rocket but got way too hot and demagnetized the motor. This is also on road with a properly shimmed and smooth drivetrain. Off road will probably be worse. I’ve found the sweet spot with the torque tuned for speed and longevity is with the 64t spur and 28t pinion both in stock gear pitch. Puts you at 5.9 fdr.
Webarno likes this.
Apexape is offline
Old 05-02-2020 | 06:46 PM
  #2463
Outdoors, loose diffs, it's a preference thing but I always ran ceramic grease in mine.
dman18t is offline
Old 05-03-2020 | 12:56 AM
  #2464
angrymelon's Avatar
Default TT02 Rally Suspension
What is more important is shock travel. The suspension cannot articulate more than the Super Mini CVAs, and if you needed it to have more down travel, you can always put on the longer shock eyelet ends.
Also, just today I finally decided to remove the little plastic bump on the lower a-arm that stops the suspensions downward travel. Removing it increased it the perfect amount! I originally thought about cutting the lower bump off the upright, but I'm glad I went this route instead.
angrymelon is offline
Old 05-03-2020 | 06:07 AM
  #2465
HI,
I just built a stock TT-02RR. I got the newest Protoform C8 Corvette body for it. The wheels are too narrow for the body, but it works okay.
Is there a way to make the track wider? I was trying to find off-set wheels but came up with nothing.
Does the TT-02SR have a wider stance?
Has anyone noticed how hard it is getting to find RC car stuff?
Jvaliensi is offline
Old 05-03-2020 | 07:19 AM
  #2466
Originally Posted by Jvaliensi
HI,
SR is wider because it uses a different(more racing oriented Suspension). If my memeory is correct, tt02sr uses 5mm hexes whereas tt02 uses 8mm to achieve the same track width.
And yes, this pandemic makes alot of things harder to get.
zxcvb1t is offline
Old 05-03-2020 | 08:14 AM
  #2467
eR1c's Avatar
HI,
Is your Corvette body 190mm or 200mm width? (you'll want a 190mm width body ideally, but if its 200mm you can still work w/ it).
You can widen the track width of your car using wider wheel hexes. Your kit comes w/ some in various sized widths (I think), otherwise you can order wider ones. Stock kit is usually 5mm width, you can get wider wheel hexes which will offset your tires.
Also, are you using the kit wheels and tires? they may be a bit too narrow looking for the body you chose. Most kit wheels are 26mm (I am guessing that is what you have)? Corvette's have wider tires in the rear, ...not sure what your using your car for (bashing or racing), but you can check out or think about putting some of these on your 'vettte (they are wider than the stock wheels):
https://www.amainhobbies.com/protofo...kaAnRCEALw_wcB
Note: you'll have to get a set for the rear which are 31mm and a set for the front which are 26mm
There are probably a lot more options for wheels/tires as well in wider sizes.
hope this helps
eR1c is offline
Old 05-03-2020 | 08:15 AM
  #2468
Kregger's Avatar
You could try these.
https://www.tqrcracing.com/shop/prod...asp?p_id=10270
also Tamiya (and other companies) make wider wheel hexes that you can use, just measure the ones you have and go from there, Just make sure you can still tighten down the wheel nut.
Kregger is offline
Old 05-03-2020 | 11:42 AM
  #2469
The kit came with two wider hexes but the axles are too short and the nuts don't go on.
Thx for the tips!
Old 05-03-2020 | 12:57 PM
  #2470
Kregger's Avatar
Tamiya make a wider axle for the standard tt-02 (TAM51529) you would have to buy 2 (only one long axle per pkg) not sure if those axles will fit on the RR though.
Kregger is offline
Old 05-05-2020 | 06:56 AM
  #2471
Suspended
The wheels and tyres that come with the TT02RR are 24mm wide inside of tamiya's usual 26mm and im pretty sure are zero off set compared to 3mm off set on all other TT01/TT02
Pablo17 is offline
Old 05-06-2020 | 07:35 AM
  #2472
The Ferrari wheels came and although they are wider they don't appear to be offset outwards much.
I also bought tires for TQ Racing only to find they don't fit the rims. They are for the racing trucks (semi's). Don't know what to do with them.
Looks like I wasted $50 here.
What 1/10 scale TC's actual are 190mm wide? I got a TT-02SR and I'm not waisting my time on it if it will look like crap.
Old 05-06-2020 | 09:01 AM
  #2473
angrymelon's Avatar
The problem isn't likely only the chassis, it's partially due to the Protoform body actually being 193mm wide. I've included the specs from their website below.
Length: 17.68" (449mm)
Width: 7.6" (193mm)
Wheelbase: 10.1" (257mm)
Like previously mentioned, finding the necessary wheel hex width, spacers, or wheel offset (or any combination) is the only way to typically get it perfect. I've personally had great success with 3Racing hexes, along with their spacers to get it perfect.
Wheel hexes:
https://www.tqrcracing.com/shop/prod...13&s_maker_id=
Wheel spacers:
https://www.tqrcracing.com/shop/prod....asp?p_id=2263
I'm not familiar with the TT02RR axles, so if getting longer ones isn't an option, deeper offset wheels might be your only choice.
Old 05-10-2020 | 10:19 AM
  #2474
I finally purchased some proper oil shocks and the high speed gear set.
Had a little blast today and the Yeah Racing shocks with the super soft springs were excellent. It’s eradicated all bounce that the pogo suspension gave.
The high speed gear set made a minor difference.
I do want a faster motor still, the torque tuned just doesn’t have enough power.
Also, I’m struggling to keep the car in a straight line after making turns.
As you turn the wheel and let go, the car still wants to go in that direction, until you turn the wheel again.
Are there any upgrades I can purchase to get rid of that and improve the steering, or at least reduce the effect?
angrymelon likes this.
Webarno is offline
Old 05-10-2020 | 11:01 AM
  #2475
NutDriver's Avatar
Webarno,
Regarding your steering issue, I would first check to see if there is bind in the steering assembly. Second, I would check the servo saver. They can get sloppy at times. The Xray heavy duty servo saver is the industry standard (IMO) and worth the $20. Third, I would ask about the steering servo you're using. Some don't center very well. Fourth, could it be due to binding in the drive train?
NutDriver is offline
