Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 02-09-2020 | 09:48 PM
  #2311
proliteandsc's Avatar
Has anyone tried installing the TRF419 upgrade kit #54886 ? Tamiya said it will work on the Type-S.
nrtv20 likes this.
proliteandsc is offline
Old 02-10-2020 | 06:33 AM
  #2312
Hoyle33's Avatar
Hey all, I have a TT-02 roller with upgrades for sale. PM me if you're interested!
Might save some of you some $$$
Tamiya TT-02 Subaru roller
Hoyle33 is offline
Old 02-10-2020 | 07:18 AM
  #2313
So.. lets say you don't want to spend the $35 for the tamiya screw kit. Here's what you need to buy:
  • M3 x 8 Button - 8
  • M3 x 10 Button - 39
  • M3 x 12 Button - 7
  • M3 x 15 Button - 4
  • M3 x 18 Button - 2
  • M3 x 10 Flat - 7
Then Tamiya specific screws.
  • M3 x 18 Step - 2
  • M3 x 14 Step - 10
These are both available from Tamiya as low friction screws. I beleive they are "Tamiya specific."
Nerobro is offline
Old 02-10-2020 | 08:29 AM
  #2314
Is that for Type-S?
Old 02-10-2020 | 09:20 AM
  #2315
No, just a plain TT02. The shock towers, shocks, will need different fasteners.
Nerobro is offline
Old 02-10-2020 | 01:59 PM
  #2316
never saw an m3x18 screw on the tt02
zaraz is offline
Old 02-10-2020 | 02:06 PM
  #2317
Part of the steering assembly.
SteveM is offline
Old 02-10-2020 | 02:48 PM
  #2318
aw that clears it up, I was looking for a normal screw not those ones got me a little worried as I just built one and did not have the m3x18 screws, if you replace the kit ones with regular screws you would need some sort of flanged tube to go n place.
zaraz is offline
Old 02-10-2020 | 09:44 PM
  #2319
Flat head screws, are the ones with the cone shaped head, so they will self center in holes, and screw in flush. They are measured from the flat on top, to the tip of the screw.
Button head screws, are the "classical" screw head. Kinda dome shaped. They are measured from under the head, to the tip of the screw.
Cap head screws, are the ones with the round, barrel shaped top. These are measured from under the head, to the tip of the screw.
Often fasteners are listed with thread length, and shoulder bolts are a thing.
I have "tamiya specific screws" before the step screws because they seem to be a very tamiya specific thing. The low friction screws that tamiya sells are machine thread, instead of self tapping. So I felt the "m3" designation was.. still proper.
Nerobro is offline
Old 02-11-2020 | 07:12 AM
  #2320
I'm looking to install the Tamiya #42287 shocks. Anyone know what springs work with them?
Old 02-11-2020 | 08:21 AM
  #2321
Raman's Avatar
42278 Large Diameter Spring Set
47317 Large Diameter Spring Set Mica blue
42293 Large Diameter Soft Spring
rippen and proliteandsc like this.
Raman is offline
Old 02-11-2020 | 10:38 AM
  #2322
Is there a chart with weight for the springs? Wanted to know how the #42278 compares to #47317 springs.
Old 02-11-2020 | 10:39 AM
  #2323
Tippman Prolite, and stock class? Or am I reading to much into the username.
Nerobro is offline
Old 02-11-2020 | 10:54 AM
  #2324
Team Associated Prolite and SC short course trucks. I tried racing them before I realized I should have got a truck made for racing.
Old 02-11-2020 | 11:30 AM
  #2325
tamiya makes a hex replacement for it anyway which tightens up the steering a hair.
Seth
sethwas is offline
