Tamiya TT02 Thread >
Tamiya TT02 Thread
Like Tree349Likes
Tamiya TT02 Thread
Old 05-10-2020, 11:42 AM
  #2476
Originally Posted by NutDriver View Post
Webarno,
Regarding your steering issue, I would first check to see if there is bind in the steering assembly. Second, I would check the servo saver. They can get sloppy at times. The Xray heavy duty servo saver is the industry standard (IMO) and worth the $20. Third, I would ask about the steering servo you're using. Some don't center very well. Fourth, could it be due to binding in the drive train?
Thank you.
Canít see any binding issues or anything like that. The current steering servo is the standard one that comes with the TT02 kit.
Webarno is offline
Old 05-10-2020, 11:49 AM
  #2477
I've managed to break the kit servo saver due to my own fault ... anyway it's well known to be sloppy and contribute a lot to the problem you're experiencing. I replaced it with the Kimbrough mid size servo saver. Been working well so far for me.
Webarno likes this.
userst is offline
Old 05-12-2020, 01:06 PM
  #2478
Ordered my servo saver now
Can anyone recommend a decent brushed motor that I can just plug and play?
Webarno is offline
Old 05-15-2020, 05:39 AM
  #2479
So I'm going to grab a TT02-based Mustang or 911 as soon as they're in stock anywhere in the US - I've started ordering some hop-ups in anticipation, including the TT02 super mini CVA shock set (54753).
I was surprised to see the instructions have you build the front shocks with 3-hole pistons, and the rears with the 1-hole - making the rear damping stiffer than the front. This seems like the exact opposite of what you'd do with a full-size car, so I looked at some of the other Tamiya instruction sheets. And they're all over the place.
TT02R builds all 4 shocks with the 2-hole pistons, #400 oil
TT02RR builds like the hop-up part: 3-hole fronts, 1-hole rears, #400 oil
TT02D builds all 4 with 3-hole pistons, #400 oil
TT02S builds all 4 with 1-hole pistons, #900 oil; but they're also the TRF shocks if I'm not mistaken
So, every TT02 version that comes with oil dampers tells you to build them differently OOTB.I get that dampers are a tunable part, but is there ANY consensus as to what the best starting point is? Not even Tamiya can make up theirs minds, it would seem. Car will be driven on unprepared asphalt (parking lot) or tennis court type surfaces 99% of time (bashing/practice/fun running), if that matters. Looking for grip/racing handling, not a drift car.
SennaPK is offline
Old 05-15-2020, 08:09 AM
  #2480
I would ignore the S and Drift Versions. S has completely different suspension and the Drifters maybe do have other requirements as a racer.
So, we only have R, RR and Set 54753 with latter 2 have similar setups. R setup is not that far away, so you can go either way.
As often, starting on middle road is not the worst, so I would go with 2 hole piston and some 500 oil for the beginning and rebuild if necessary.
Michael
JJ100179 is offline
Old 05-15-2020, 09:57 AM
  #2481
Thanks, that makes a lot of sense. The R instructions seem to be right in the middle-ground of settings, so maybe I'll go with that to start.
SennaPK is offline
Old 05-20-2020, 02:51 PM
  #2482
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Old dog new game. What's the TT02 max min tooth count of the pinion and spur set? Largest pinion and spur and the smallest pinion that still reaches with the same spur. I have the YR motor mount and spur adapter (high speed gear set) on the way. I'm looking to end up in the 3.8 (55/36) FDR range for some 21.5 racing. The car is an SR and a WHIP. I'm waiting on a few more deliveries before I can run it. I'm also getting all Tamiya upgrades to stay TCS legal if we ever get to race again.
Thanks,
John
liljohn1064 is offline
Old 05-20-2020, 06:14 PM
  #2483
Kremzeek's Avatar
With the Tamiya motor mount, you can run a 29T pinion with the 64T spur. Gets you down to 5.74
liljohn1064 likes this.
Kremzeek is offline
Old 05-20-2020, 09:39 PM
  #2484
tomthegeek's Avatar
New shocks included a holder (from sprue) some assembly required.
tomthegeek is offline
Old 05-21-2020, 02:56 PM
  #2485
It should be here tomorrow. I can play with it. I have a few TC3s laying around for comparison. They are the reason I went with the SR version. Hope to see you and the other racers this weekend.
Old 05-21-2020, 05:56 PM
  #2486
Kremzeek's Avatar
I've got a set of TRF pistons that I need to put in mine. I'm too lazy to take them apart just for that.
Kremzeek is offline
Old 05-21-2020, 07:48 PM
  #2487
tomthegeek's Avatar
How many holes do they have? I'm using the single hole pistons one these same as what they came with. Pretty easy maintenance really was expecting more of a pain. I used our food vacuum sealer to bleed the air out lol.
I finally got a set of springs in but somehow did not notice they only come with 2 of each spring. So now I need to order another set. I'm gonna run the stiffer set in front for now.
Old 05-22-2020, 08:29 AM
  #2488
Kremzeek's Avatar
I got the 3 hole ones. I tried running with really stiff springs all around and didn't like it. That might work well on carpet, but I wasn't getting the traction I wanted on asphalt. I may actually go back to the softer kit springs on the rear.
tomthegeek likes this.
Kremzeek is offline
Old 05-25-2020, 05:22 AM
  #2489
Ok need some help.
Iíve just fitted a Tamiya 64T spur gear, along with a 48P 28T pinion gear.
I'm using the standard plastic motor mount whilst I wait for my YR adjustable one to arrive.
Iíve got it to fit nicely, but it sounds awful!
Like a sort of grinding sound. Previously it was nice and quiet, but after fitting these bits, itís very loud. Is that normal, or have I done something wrong?
I have greased the gears too.
Webarno is offline
Old 05-25-2020, 05:34 AM
  #2490
SteveM's Avatar
Trader Rating: 160 (100%+)
Did you use a Tamiya pinion?
SteveM is offline
