Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 05-25-2020 | 05:49 AM
  #2491
Originally Posted by SteveM
Did you use a Tamiya pinion?
No, I couldn’t find one that was 28T.
I bought one from eBay.
Forum won’t allow me to post the link, but the item number is 274341095112
Webarno is offline
Old 05-25-2020 | 10:34 AM
  #2492
Originally Posted by Webarno
Ok need some help.
I’ve just fitted a Tamiya 64T spur gear, along with a 48P 28T pinion gear.
I'm using the standard plastic motor mount whilst I wait for my YR adjustable one to arrive.
I’ve got it to fit nicely, but it sounds awful!
Like a sort of grinding sound. Previously it was nice and quiet, but after fitting these bits, it’s very loud. Is that normal, or have I done something wrong?
I have greased the gears too.
The Tamiya aspur gear (Module 0,6) does not match the 48dp pinion.
If you convert 48 dp into the metrical system you will have module 0,53. (1/48*25,4)
Vice versa: module 0,6 is more equivalent to 42dp.
​​​​​​The result of the combination with real module 0,6 is not smoooth, but "pepper mill"
Kremzeek and Webarno like this.
JJ100179 is offline
Old 05-25-2020 | 06:53 PM
  #2493
Kremzeek's Avatar
You want this:
https://www.tamiyausa.com/shop/optio...uorine-coated/
Kremzeek is offline
Old 05-25-2020 | 07:47 PM
  #2494
Kremzeek, kremzeeeeek!!!!
Kremzeek and tomthegeek like this.
ittjv is offline
Old 05-26-2020 | 03:07 AM
  #2495
Originally Posted by Kremzeek
So that will prevent the grinding sound with the Tamiya 64T Spur gear?
I can't see what the difference is with that pinion compared to the one I've purchased, unless it's just the coating?
Webarno is offline
Old 05-26-2020 | 03:52 AM
  #2496
Tamiya 64T spur gear is Module 0,6
Your pinion ist 48dp Module
Kremzeek's pinion is Module 0,6.
48 dp does not match Module 0,6 (see posts above), layout shape and size of tooth is different
Okay?
Kremzeek likes this.
JJ100179 is offline
Old 05-26-2020 | 05:22 AM
  #2497
Okay?
I'm new to all this stuff, so the above doesn't make much sense to me, apart from the fact it seems I've bought the wrong pinion?
Webarno is offline
Old 05-26-2020 | 05:37 AM
  #2498
Trying to find the Tamiya 28T pinion in the UK seems impossible.
Would this work:
https://wheelspinmodels.co.uk/i/316877/
Webarno is offline
Old 05-26-2020 | 06:05 AM
  #2499
This will work!
Webarno likes this.
JJ100179 is offline
Old 05-26-2020 | 12:04 PM
  #2500
liljohn1064's Avatar
I got the 3 hole ones. I tried running with really stiff springs all around and didn't like it. That might work well on carpet, but I wasn't getting the traction I wanted on asphalt. I may actually go back to the softer kit springs on the rear.
Are the SR Kit springs softer than the red springs?
liljohn1064 is offline
Old 05-26-2020 | 02:05 PM
  #2501
Robinson Racing sells the Tamiya compatible pinions in .6 module.
SteveM is offline
Old 05-26-2020 | 02:10 PM
  #2502
Tamiya uses it's own proprietary gears, in .4 and .6 module which looks like 64P and 48P but isn't.
If you use the Tamiya high speed gear set (TAM54500) but do not use the included Tamiya spur gear from the kit, you can use traditional 48P or 64P spur and pinion gears. This option would give you the most flexibility on gearing.
Webarno likes this.
SteveM is offline
Old 05-26-2020 | 02:27 PM
  #2503
Would this work:
Yes, It's mod 6 with a 3.2mm bore (1/8"). Most motor shafts are 1/8" Standard.
Old 05-26-2020 | 03:41 PM
  #2504
Thanks a lot for all the replies. Very helpful
I clearly still have a lot to learn.
Webarno is offline
Old 05-26-2020 | 05:33 PM
  #2505
Kremzeek's Avatar
If they're the same as the ones in the RR kit then they're quite a bit softer than the red springs.
liljohn1064 likes this.
Kremzeek is offline
