Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 02-28-2018 | 10:19 PM
  #1711
Originally Posted by craig santry
what tires were you running?
Kit stock rubber tires, but I tried a different set that someone loaned me with the same results.
I am thinking that it is in the drive train because going straight and turning left there are no problems
RONAMYTH is offline
Old 02-28-2018 | 10:20 PM
  #1712
Originally Posted by simple
...I'd also double check the bearings in the outdrives, as well as verify your steering travel is the same left to right, lock to lock.
Bearings are fine and steering is the same left and right
RONAMYTH is offline
Old 02-28-2018 | 10:26 PM
  #1713
Originally Posted by f1larry
Any secrets on how not to pop out dog bones (besides not hitting anything) for a box stock (except for super mini shocks and aluminum motor mount) car?
Unfortunately no tricks or secrets, just have to replace with 53792 universal shaft assembly or equivalent
RONAMYTH is offline
Old 03-02-2018 | 07:40 AM
  #1714
No testing this week. Damn weather. Question on motors now.
Im running a sport tuned which is about the pace we all run. Id likento go brushless for increaded run time not more speed. Would a 17.5t be roughly in the same region as the sport tuned but give increased run time?
Jay12341985 is offline
Old 03-02-2018 | 07:45 AM
  #1715
I could be wrong but I think they range between 23t and 27t. Do you have a model number you can provide?
I think a 17.5t motor would be much faster than the sport tuned.
DoubleRR24 is offline
Old 03-02-2018 | 12:43 PM
  #1716
simple's Avatar
I think increased runtime would be an incorrect expectation to switch to brushless.
Brushless provides reduced maintenance and increased speed/power. The gear ratio will be completely different for brushless, so if you go that route, you'll need the spur gear mod and go to a much smaller 64pitch spur than what is stock with the kits.
If you want more runtime, upgrade the lipo cells to a higher capacity.
simple is offline
Old 03-02-2018 | 01:08 PM
  #1717
so it was a 17.5t brushless i was thinking, i think the sport tuned is 23t (brushed) I thought they may have been comparable but maybe im off, maybe 21.5t would be closer?
yeh i already have the high speed gear set in. i will gear it to run roughly the same speed as i run now.
I run with a few other guys and we want competition so im not after higher speed
but in general if using a brushless system vs brushed if your doing roughly the same work then brush less is more efficient and so all else being equal uses less power.
its certainly true in other applications but other factors could be at play here?
Old 03-04-2018 | 09:05 AM
  #1718
wtcc's Avatar
My friends and I had an awesome weekend taking part in the Tamiya Euro Cup Stock class (TT-02 box stock, even esc and motor). I could win the class after hard fights through qualifying and finals.
Here is the full story:
https://www.facebook.com/blautalrcca...90338654417875
And videos:
https://m.youtube.com/watch?t=119s&v=XBJRy8YleXs
https://m.youtube.com/watch?v=WgXBs2NL-8U
eR1c likes this.
wtcc is offline
Old 03-04-2018 | 02:07 PM
  #1719
f1larry's Avatar
Fix
f1larry is offline
Old 03-05-2018 | 12:29 AM
  #1720
JD Skyline's Avatar
[QUOTE=wtcc;15173603]My friends and I had an awesome weekend taking part in the Tamiya Euro Cup Stock class (TT-02 box stock, even esc and motor). I could win the class after hard fights through qualifying and finals.
And videos:
Congrats with your win. Nice videos and pictures...
cartix and eR1c like this.
JD Skyline is offline
Old 03-08-2018 | 12:18 AM
  #1721
Default Torque Tuned Motor
Which of the kits come with the Torque Tuned Motor ?
The motor specs are not helpfull, some sites say Torque Tuned , other sites say
plain ol 540 motor.
The local TT02 race class uses the Torque Tuned Motor as spec motor, so I really need to but the kit with that included, not a kit with the old standard silvercan
1101 is offline
Old 03-08-2018 | 09:30 AM
  #1722
wtcc's Avatar
All 2015 Super GT kits got one: Autech Nismo Nissan GT-R, Petronas Lexus LCF and Raybrig Honda NSX.
Also the Raikiri GT
wtcc is offline
Old 03-08-2018 | 10:35 AM
  #1723
eR1c's Avatar
My son runs a TT02 in our novice class, I started w/ the silver can, then the sport tuned, then a 21.5t and now a 17.5t. The car is definitely fastest w/ the 17.5t motor in it. I've gradually increased the speed as my sons skill has increased. This is all over a year and a half time period. ...keep in mind though that even if you put a 17.5 in the car you can gear down and turn your throttle down on the controller to slow it down (I actually turned ours down a bit as the 17.5 was a tad too fast for him).
The TT02 has been a great car, ...its pretty solid can take a beating and parts are easy to find and not expensive.
eR1c is offline
Old 03-10-2018 | 01:25 AM
  #1724
rc_square24's Avatar
Just built my TT02 a few weeks ago. I got the chassis from the 99' Impreza kit which I originally bought for its rereleased body only, left the car unbuilt until I started running with a group of guys that does weekend parking lot racing.
I have to say I'm quite impressed with the kit even in box stock form, drives nice and the drivetrain is definitely much quieter than the TB01 I used to own.
I have since upgraded the driveline parts, as well as the steering. Threw in a set of YR dampers I had laying around.
The YR steering set is nice for its price compared to the Tamiya. I added two extra 3x6 bearings on top of the bridge that took all the slop out, however the screws need to be held by thread lock to avoid binding the bearings.
Now with the YR motor mount I'll be switching from 21.5 to a 17.5
rc_square24 is offline
Old 03-12-2018 | 08:44 AM
  #1725
I finaly got some run time last week. The vampire racing 17.5t is great! I geared at around 96/42 and ran at 1/4 timing on the motor and the car is exactly comparable to how it ran with the sport tuned running 68/22 when benchmarked against a few friends. For info 2 are running a hpi firebolt 15t which is actuqly comparable to the sport tuned the way we are running.
Question on my set up. I am.running super mini cva. Blue rear. Yellow front. I find thatvthe car is great but tlwhen it does let go the front hooks badly and i go tound in circles. Im running 2mm spacers in the cva's frontand rear to reduce droop but i still find adding a lot of preload to the rear to give me zero droop at the back gives me a very stable and planted rear end. I can take huge liberties going into conrners and its fine.
Any thoughts on that. Should i just add more spacers to the rear to reduce rear droop further?
