Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 02-24-2018 | 12:13 PM
  #1696
Raman's Avatar
What sort of surface are you running? Asphalt?
Best way to set up the car is to first set up ride height with preloads. 5mm front and back is a good start. Then you want to set up the suspension droop.. how much the arms droop down when you pick up the front with the tower and the back. When you pick up the front, you want the arms to droop very little... maybe 0,5 mm. Rear you want about 1-1,5.
To achieve this, you either need to buy the optional droop tabs for the type S suspension, or place o-rings inside the dampers to reduce the downward movement
The balance between front and rear will help the behaviour of the car on corner entry, mid corner and corner exit. It all depends on surface etc
Raman is offline
Old 02-24-2018 | 01:11 PM
  #1697
Hi thank you yes dropp was going to be next to try. So with stock springs i dont get low enough i have 2 blue springs to try untill the full kit turns up but that feels very soft. Are you running the stock tower and arm mount holes?
It feels like with such a small amount of droop ill be running on the bump stops when braking and turning. Is that right?
Even with blues on the car feels soft
Jay12341985 is offline
Old 02-24-2018 | 01:27 PM
  #1698
I suppose that should be running in the droop or rebound stops �� im also wondering about the hooking i experianced when i was running with justvthe atock spring with no preload. That would of had me at the closest to 5mm i have run but the car felt like it had a lot of weight transfer and also hooked badly mid corner.
This is all on a very good condition ashphelt car park so medium grip as its cold
Old 02-24-2018 | 02:11 PM
  #1699
Raman's Avatar
Tamiya blue springs are actually the hardest springs. For asphalt, I would run yellow on front and red in rear.
Raman is offline
Old 02-25-2018 | 02:45 AM
  #1700
Ah ok. I didnt think they should be do soft. Will that not make the hooking mid corner worse? Thanks
Old 02-25-2018 | 12:51 PM
  #1701
Raman's Avatar
Test it out
Raman is offline
Old 02-25-2018 | 02:22 PM
  #1702
i will. Time is very limited for testing. I get a short time each week to.play hense the research. Are you using the trf ahor springs to get the ride hight?
Old 02-25-2018 | 08:08 PM
  #1703
Nortran11's Avatar
Ran my TT02 S on carpet for the first time this week.....what a pig. While I drove it to second place, it was the hardest I've ever had to drive that car. It pushed hard in corners, the lack of sway bars was very evident in the high speed corners. I think I've come up with a solution that will allow me to mount sway bars (I'll post it if it works)
Nortran11 is offline
Old 02-25-2018 | 10:19 PM
  #1704
Raman's Avatar
This was my set up in usgt for carpet
Ride height 5
Droop - 2,5 over ride height in front and 1,5 in rear
Camber - 1,5º all around
Front toe - 1,0º toe out
Dampers TRF419 big bores
Shocks Muchmore 400 wt
Springs Muchmore X springs Red front (firm) Pink rear (medium)
Diff - Front epoxied / locked, Rear 10k (using my diff mod in this post R/C Tech Forums - View Single Post - Tamiya TT02 Thread
Car was extremely competitive. I stopped running it because of the rear portion of chassis breaking when rear axle stud would catch a pipe and break... I even broke the hardened chassis this way..
Raman is offline
Old 02-25-2018 | 10:49 PM
  #1705
Nortran11's Avatar
That's almost a mirror copy of my setup. I'm running a ball diff in the rear, locked in the front.
The only major difference is dampers. I'm running TRF black coated with stiff front springs and med rear springs.
This was on grey CRC carpet with SXT 3.0 sauce on Gravity USGT tires
Old 02-25-2018 | 10:55 PM
  #1706
thanks you thats great info, realy appreciate it. I rebuilt the shocks last night (mini CVA) with a some orings to reduce my droop, im still not down to 5mm ride hight so when the springs arrive ill try the medium rear and see if that gets me where i need to be. i rebuilt with a 35wt oil with the 1 hole piston. I have around -1.5 up front -2 in the rear with unknown toe, im guessing at around 1deg. also running heavy oil in the front diff, this did help last week. thanks again for the info, ill see how this setup works :-)
thanks again.
Old 02-27-2018 | 09:23 AM
  #1707
Got a box stock TT02 for my son to run at TCS events in novice. Car ran fine in practice on black carpet. First qualifier got some traction roll, so between quals I super glued sidewalls. Second qualifier car ran great when making left hand turns but would spin out on right hand turns. Could not find anything mechanically wrong with the car, looked at diffs, dogbones, etc...nothing-even tried different tires with same result. In final car did same thing. Got home and still can not find anything wrong with car. HELP! WHAT IS GOING ON? THX
RONAMYTH is offline
Old 02-27-2018 | 05:01 PM
  #1708
craig santry's Avatar
what tires were you running?
craig santry is offline
Old 02-28-2018 | 03:34 AM
  #1709
simple's Avatar
...I'd also double check the bearings in the outdrives, as well as verify your steering travel is the same left to right, lock to lock.
simple is offline
Old 02-28-2018 | 03:50 PM
  #1710
f1larry's Avatar
Any secrets on how not to pop out dog bones (besides not hitting anything) for a box stock (except for super mini shocks and aluminum motor mount) car?
f1larry is offline
