Team Associated TC6 Thread >
Like Tree20Likes
Old 02-26-2012, 06:50 PM
  #5941
geeunit1014's Avatar
Trader Rating: 14 (100%+)
Originally Posted by BMenard17
Is the ballast weight kit stackable? I need to reach a 1550g weight for VTA so Ill need two sets.
https://www.ssl-stormerhobbies.com/c...ns&pn=ASC31296
Yes they are
geeunit1014 is offline
Old 02-26-2012, 06:53 PM
  #5942
BMenard17's Avatar
Trader Rating: 88 (99%+)
Originally Posted by geeunit1014
Yes they are
BMenard17 is offline
Old 02-26-2012, 11:33 PM
  #5943
X14
It was totally dialed in the main. Not really sure how my motor compared to the two leaders but one of them said I was catching them. Unfortunately I got too far back early on to dice it out with them but a 3rd place finish with a bunch of great 17.5 racers was fine for me first time out racing sedan in 8 years
Can't wait to run mod in the near future
I will try the Team Powers 36R tires[/URL] next time to see how they do since they are the Reedy tires.
Later[/QUOTE]
tnx for posting... your car rans like mod and TP might hav some grip since most of the guys on track were running those tires.
X14 is offline
Old 02-27-2012, 09:40 AM
  #5944
Suspended
Trader Rating: 86 (100%+)
Later
tnx for posting... your car rans like mod and TP might hav some grip since most of the guys on track were running those tires.[/QUOTE]
would you please show your setup for reference?
did you ran on carpet?
littlealex is offline
Old 02-27-2012, 10:27 AM
  #5945
Infinite 12th's Avatar
X14 messed up his quote of my post
It was asphalt in Northern California at Norcal-Hobbies
Here is the 17.5 blinky setup again
Infinite 12th is offline
Old 02-27-2012, 12:42 PM
  #5946
JustWill75's Avatar
I race with a lot of xray and serpent drivers and talk of low friction super flexible drive belts came up. Do you really notice a diffrence between belts and who makes one for the TC6
JustWill75 is offline
Old 02-27-2012, 12:46 PM
  #5947
front belt => trf 416
rear belt => use ae
I do not see difference for softer belt from trf or yokomo at front
it lost tooth on hard breaking in modified
regards!
m
M.Abramowicz is offline
Old 02-27-2012, 01:03 PM
  #5948
RAL
RAL's Avatar
Trader Rating: 67 (100%+)
Rick will the Team Bomber ones fit for the BD5?
http://www.rc-race-and-drift-japan.c...oducts_id=2661
RAL is offline
Old 02-27-2012, 01:09 PM
  #5949
ill try to ask again, hate to race with the car and not having any spares in the box (there is no local hobbystore where i race..)
since there are no tc6.1 parts in stock anywhere, what "old" tc6 suspension parts fits on the car?
really needs a answer so ican order some spares.. or does anyone know any onlinestore that has the 6.1parts in stock?
Bappe is offline
Old 02-27-2012, 01:29 PM
  #5950
I gave some T6 Chubs to a guy who needed them for his 6.1 He made them work. I dont think anything else will work but im not sure. I know the arms and steering blocks were changed as well. Im not sure if you can use the rear hubs either...probably but you would have to account for the toe angle.
Good luck...its sad when we cant get AE parts .....its one of the reasons i went with the TC6.
wcalaker is offline
Old 02-27-2012, 01:48 PM
  #5951
Originally Posted by Maybell
Those should work fine. If you have a spur/pinion alignment issue, you will have to cut the motor shafts flat-spot back a little.
You mean grind the shaft a little with a Dremel tool?
So that there is more flat spot towards the motorcan?
And therefore the pinion can be put further on the motoraxle?
Just checking, because English is not my native tongue.
Are there pinions that can be used without any grinding or other alterations?
Anybody any experience with these LiPo's?
http://www.rc-mushroom.com/product_i...n-case-p-23725
They are a bit on the heavy side, 316 grams. Would that be a problem as to being as close as possible to 1,350 grams for the car raceready?
Or better not to touch them and go for IP or Orion or so?
Kensei is offline
Old 02-27-2012, 01:51 PM
  #5952
yes, just dremel the flatspot so it is closer to the can, i did this to have more clearence between the pinion and the belt, i use 3racing, robinson and rw pinions... 30sec job and youre done! just make sure to cover the holes on the motor so the metal dust dont get in there!
Bappe is offline
Old 02-27-2012, 01:59 PM
  #5953
Jochim_18's Avatar
Does anyone make aftermarket chassis and topdeck for TC6?
Jochim_18 is offline
Old 02-27-2012, 04:20 PM
  #5954
pressure's Avatar
Default M. Haynes runs TC6.1 for the first time....preview
Mike Haynes National Champion runs his TC6.1 for the first time at 360 V2 raceway in New Roc NYC
http://youtu.be/JOnqnxh-3ok
pressure is offline
Old 02-27-2012, 05:08 PM
  #5955
Trader Rating: 38 (100%+)
Does anyone know if the xray rear body mounts fit the TC6? Thanks.
or8ital is offline
