Team Associated TC6 Thread
#5191
Maybe someone has some at home to check exactly what is required.
#5192
Battery strap
Just bought a tc 6.1 and was wondering length wise, what battery strap works? 4"? 6"? If there is one out there that is commonly used (company, etc) that info would also be helpful. Thanks in advance.
#5194
#5195
I use the TOP battery strap...
http://www.amainhobbies.com/advanced...-BMT01&x=8&y=8
#5196
just went and measured mine and overall length is about 13 inches
#5197
#5198
New racer here...
There's one slight right hander at the course I'm running which I continue to slap with the side of my car (TC6). I have broken two rt rear hubs and one rt steering block during fairly light collisions with this corner.
Two quick questions:
1. Has anyone else experienced fragility in the rear hubs or steering blocks of their TC6?
2. How would you compare the integrity/longevity of the TC6.1 vs TC6 as it pertains to these two areas?
To me, it looks like the 6.1 has a considerably thicker top portion of the rear hub with less of a "reach/rake" to the inner ball stud holes than the setup of my hubs. It's hard to tell though from the pics I've seen.
The steering blocks on the 6.1 seem to be insignificantly different.
Any thoughts would be greatly appreciated.
loop
PS...I've only done a few hot laps with the car so please bear with my lack of ability to avoid collisions with obvious barriers in the track. I need to get better on the wheel...don't hit anything...don't break!
loop
#5200
Did you break them by basically ripping the ballstud out? You can get the 10mm length ballstuds if you are running any shims under the ballstuds which helps with this. With the rear hubs, you can also put a grub screw in the unused hole which beefs it up. I have never broken or stripped out a rear hub on my car. I have stripped out a few knuckles, but I rarley out and out break them unless the c hub breaks, which can take the knuckle with it.
#5201
Hi,
Does anyone know if the 6.1 chasis compaitable with the 6?
#5203
New racer here...
loop
loop
Yep !! the easiest is to stop hitting parts of the track unfortunately...
#5204
Pinion size
Going to be running 17.5 blinky or not depending on class running. I have an 87 (stock spur) and was trying to figure out a starting size for pinion. What FDR should I be aiming for? 4.00? I searched thru a few pages here and there but no real luck. Thanks.
