Team Associated TC6 Thread >
Like Tree20Likes
Old 09-05-2011, 01:19 AM
  #3691
Had no problems with reinforced tape, just make sure to round the edges of little carbon battery holder plates.
Change tape every 4/5 packs to be safe, mainly due to dust when blowing car clean
olly986 is offline
Old 09-05-2011, 01:34 AM
  #3692
can someone help me the wheel base to make it shorter dou change the shims at the front of the a arm and the other side of the a arm at the front as well the to corners and the same at the rear cause i want to ran 1mm shims so for ask a stupid question guys
bunny32 is offline
Old 09-05-2011, 05:47 AM
  #3693
Big Features's Avatar
Originally Posted by bertrandsv87
Zero issues until it decides to let go of your battery in the middle of the main !!! I don't trust them at all; loose top carbon strap holding down a battery that can't move side to side and back and forth is the best solution to me so far ! I went from last in a main to a third place finish because most of the other racers had their batteries fall out, after changing their tape for the main ...Wow....what a waste.....Www
I think I've had a battery fall out once in 20 years.
Big Features is offline
Old 09-05-2011, 07:11 AM
  #3694
If you want a shorter wheelbase (1mm) put a 1mm shim at the back of front hinge pin and at the front of rear hinge pin.
Hope this answers your query.
olly986 is offline
Old 09-05-2011, 07:29 AM
  #3695
cwoods34's Avatar
Agreed, any time the battery has fallen out on me it was my fault. OR I got t-boned so hard that the battery isn't my first concern anyway.
cwoods34 is offline
Old 09-05-2011, 07:31 PM
  #3696
olly do u mean put a shim on both ends of the a-arm at the front and the rear as well. on ure set up sheet u have 1mm wheelbase did u make the wheelbase shorter by putting a 1 mm do u know what i mean
bunny32 is offline
Old 09-06-2011, 04:20 AM
  #3697
Well it depends how short you want it, the shorter would be no shims at all on front of rear arm and at rear of front arm.
then you can have a shim either at the front or rear, if you look at a set up sheet it is fairly well explain, they take the front shim for front and rear shim for rear to give you a spacing measure, then match up another shim on other side of arm so that there is no play.
olly986 is offline
Old 09-06-2011, 07:31 AM
  #3698
ok i got u so on ure set up sheet u got 1 mm wheelbase where did u put the 1mm shim on the a-arm on both side or just one side of the a-arm. if u put it on one side only what size did u use on the other side. im sorry just confussed
r u running short wheelbase or long wheelbase sorry olly
bunny32 is offline
Old 09-06-2011, 01:25 PM
  #3699
Where did you get my setup sheet?
There is a total space of 3mm all together, so if you use 1mm (as of setup sheet) then you have 2mm on the other side. It might happen that you need to put a very fine shim (metal) if you have too much play but the arm should be "loose"
long or short wheelbase depends on your track, use shorter wheel base for tight twisty track and longer wheelbase for long fast track.
olly986 is offline
Old 09-06-2011, 09:43 PM
  #3700
i got ure setup sheet from ae site at halifax on the 21/22 august
i got u now but if just say i want to run short wheelbase i need to put a 1mm shim on the a-arm on the rear of the front a-arm and a 2mm at the front of the arm at the front to make that a short wheelbase.
on ure setup sheet u have 1mm on ure wheelbase ok so what do u guys mean by 1mm wheelbase on the front and rear on set up sheet. some guys they say on there setup sheets that they run 2mm at front and 1mm rear what do they mean olly
bunny32 is offline
Old 09-07-2011, 02:49 AM
  #3701
Hey bunny, swap your shims already, see how it works for you
xagtho is offline
Old 09-07-2011, 04:21 AM
  #3702
TC6 Portuguese National 13,5T Boosted Champion
All my setups from the year here
jorgesimes is offline
Old 09-07-2011, 05:06 AM
  #3703
sandsurfer's Avatar
Trader Rating: 20 (100%+)
The setup sheet shows where wheelbase adjustment is. They are not easy to recognize, so I marked it in yellow, so you can see where it is.
Attached Thumbnails Team Associated TC6 Thread-tc6_editable_blank_2010-800x620-.jpg
sandsurfer is offline
Old 09-07-2011, 06:20 AM
  #3704
thanks mate for ure help
bunny32 is offline
Old 09-07-2011, 10:43 AM
  #3705
Yep we take these positions to set our wheelbase setup and fill the opposite side with another spacer like Sandsurfer showed you.
Well done Jorge !!!
olly986 is offline
