Team Associated TC6 Thread >
Like Tree20Likes
Old 03-07-2012, 06:35 AM
  #6091
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
Default Thanks for the input!
Originally Posted by ekim628
I would check Arm Hinge Pins and diff/spool blades. Sometimes the new 6.1 castor blocks crack and you wouldnt know it until you checked. Everything else on the car is solid as a rock.
i should have it in my hand on friday! I will check all of the areas you suggested! Thanks
another question: Whats the must have upgrade/aftermarket parts for a TC6?
BlackStarRacing is offline
Old 03-07-2012, 06:41 AM
  #6092
d2dap636's Avatar
Rear gear diff is the must have imo.
d2dap636 is offline
Old 03-07-2012, 07:30 AM
  #6093
JustWill75's Avatar
+1
Out the box the car is great. Its a Beast with front spool and rear gear diff.
The only other thing I see others are trying is other manufactuer's Shock springs and pistons. Im using Losi #57 pistons on my car tonight. I also have a spring set and pistons coming from Reflex racing this week.
Have fun with the car and practice as much as you can. That is still the most important "must have part"
JustWill75 is offline
Old 03-07-2012, 08:43 AM
  #6094
Default Agree on practice...the smoothest driver wins the race!
Originally Posted by JustWill75
+1
yeah I'm buying some pvc to set up my own parking lot track... I'm here in hot south florida and on road racing is so hard to find....sucks bad but I'm looking at a thread on here i think its reflex racing...not sure they have a spool gear... do you know if its any good? also are their springs good?
Old 03-07-2012, 08:52 AM
  #6095
cwoods34's Avatar
The springs are amazing. I'm using them on both my TC6 and S411, and I've had some local XRAY guys purchase and use them, also. Same thing with the fan mount...... I've got guys running them on all 3 brands mentioned, too!
cwoods34 is offline
Old 03-07-2012, 08:56 AM
  #6096
Default ordering today!
so the springs are great, the fan setup is worth the buy....any news on the spool?
Old 03-07-2012, 10:02 AM
  #6097
Infinite 12th's Avatar
Anyone know what hole to use with the roll center RSD suspension block locks? There are three holes
Middle one?
Thank you
Infinite 12th is offline
Old 03-07-2012, 10:07 AM
  #6098
cwoods34's Avatar
Associated already makes both a slipper and solid spool....... Reflex does have DCJ shafts coming out. They sell Spec-R gear diffs, which are ok but I like Associated's gear diff much better.
cwoods34 is offline
Old 03-07-2012, 10:12 AM
  #6099
Default thanks for the input!
ok so ill look at the TA site for the spool!
May i ask you if you have any setup sheets? or better yet what kind of fluid set ups are you running?
diffs
shocks
Thanks for all the input!
(I'm sure its been mentioned just too many pages lol)
  #6100
briankstan's Avatar
I just ordered the AE front spool and the gear diff for the rear. I'll be giving this setup a try. Right now I love the way my TC6 drives, but always looking for some improvements.
the Reflex Racing Springs, Shock Bladders, pistons disks, and Fan Mount are all working fantastic on my car.
briankstan is offline
Old 03-07-2012, 10:17 AM
  #6101
going to try yokomo springs this weekend.
what is different between ae springs and the reflex ones? (apart from more spring rates with reflex)
has anyone tried tamiya springs?
Bappe is offline
Old 03-07-2012, 10:32 AM
  #6102
geeunit1014's Avatar
Trader Rating: 14 (100%+)
The RSD springs feel softer, more progressive than the AE springs.
I havent ran tamiya springs on this car, but tamiya springs are very progressive.
geeunit1014 is offline
Old 03-07-2012, 10:42 AM
  #6103
Do you guys know the rates for the yokomo springs thanks
f1o7x9 is offline
Old 03-07-2012, 10:47 AM
  #6104
RussF's Avatar
Trader Rating: 22 (100%+)
Default Setup Questions
I bought a used TC6 and was going through it to make sure how it was built. Its seems that for the most part the kit instructions were followed. Since I've not ever raced a TC6 I thought I would put on the stock kit setup in the back of the manual. The setup on the car was already pretty close. I did have a couple questions though.
1. On the Suspension Geometry section it calls for "Silver + 0" on the front outer ball & shims. What is "Silver"? Does it come in the kit?
2. On the Alignment section it calls for the Steering Link to be "2B". Is "B" the outer bumpsteer location? Whats is the "2", the pivot point?
Car will be run on Carpet with Rubber Tires and 17.5 blinky class.
Thanks for any help.
RussF is offline
Old 03-07-2012, 11:19 AM
  #6105
spring rates:
Yokomo
Spring Rating [lb/in]
Orange 18.87
Green 16.06
Pink 14.93
Yellow 14.71
White 12.94
Blue 12.12
Rayspeed
Gray 19.90
Red 18.26
White 17.17
Yellow 14.87
Blue 14.29
Green 13.20
Associated
White 40.00
Yellow 31.91
Purple 30.30
Copper 23.26
Red 23.08
Gold 18.35
Blue 16.53
Silver 13.89
Green 11.43
Tamiya
Purple 22.72
Gray 20.91
White Short 17.24
Blue Short 15.27
White 14.82
Blue 14.08
Yellow 13.33
Red Short 13.24
Yellow Short 12.90
Red 11.86
3Racing
4.25T 35.8
4.50T 31.7
4.75T 29.2
5.00T 26.2
5.25T 24.9
5.50T 22.9
5.75T 21.2
6.00T 20.0
6.50T 17.9
Hpi
Spring Rating (lb/in)
Silver 08.60
Gold 11.20
Orange 12.00
Yellow 12.70
Red 13.30
Green 13.80
Blue 14.00
Pink 14.70
Xray
2.2 12.56
2.4 13.70
2.6 14.85
2.8 15.99
3.0 17.13
3.2 18.27
3.4 19.41
Bappe is offline
