Team Associated TC6 Thread
#7591
FS: factory team TC6.1 with hopups and lots of spare parts.
http://www.rctech.net/forum/r-c-item...t-tc6-1-a.html
#7593
Good question. I use them and my car runs fine. There is no noticeable difference between shims and offset armmounts for me in the race.
The only reason I can think of is that they maybe don't want/need the full 2mm offset, or came from less shims from the training/last race and wanted to save time by just adding shims instead of changing the armmounts.
#7595
Do many of you run the gear differenential in your TC6?
I have tried and tried, but the fact is that I just don't drive a spooled car as well as I do one with a front diff. I'd like to convert mine over to a gear differential. Their #31344 is $40 per set. Expensive!
#7596
For the last race I changed to gear diff in front with 3000cst oil (1000cst in rear one). Drove spool before and the car was awesome after the change. It had much more traction all around. Everything on medium grip carpet on a tight technical track with a 17.5t motor blinky class.
#7597
You are singing my song!
Did you buy your gear diffs new or are the the kind of thing you can find used?
#7598
Thanks for the replies guys.
#7599
Slipper spool and geardiff are my favourites. They work nearly without maintenance and conserve the drive train.
#7600
What I found with both cars was that the Gear diff dove into corners a bit more, and was smoother through the corner. With the spool, corner exit traction was much, much better. I prefered the feel of the gear diff, and could drive it more consistently, but the spool was still faster because of the corner exit traction and our tight/technical track layout. Playing around with front droop made it easier to drive, and I eventually got used to it.
This season I'm only running the Schui (sold the TC6 because I wasn't any faster with it, and it was worth more ), but I have added the DCJ front driveshafts. IMO, it's the best of both worlds. You get the corner exit traction of the spool, but it's much smoother and feels more like a gear diff into and through the corner. So I'm quite happy with them.
-Mike
#7601
hi guys, i am running a tc6 and thinking about buying the 6.1 arms and hubs to update all 4 corners' suspensions. do i need to buy the new CVD's as well? if not, what size bearings will fit in? have anyone tried this?
so far what i've found is the tc6 CVD's use 6x10x3mm bearings and tc6.1 CVDs use 5x10x4mm bearings. I wonder if I can get away with tc6 CVDs in the new hubs with 6x10x4mm bearings.
#7602
http://www.petitrc.com/reglages/asso...6/TC6-2-TC6.1/
#7604
#7605
