Team Associated TC6 Thread >
Like Tree20Likes
Old 10-21-2012, 08:49 AM
  #7741
Originally Posted by CL
FYI:
Associated is selling TC6.1 for $250 on their website special.
Hmmm. At that price I could almost get one and then convert it to a WC...
Vostok 7 is offline
Old 10-21-2012, 08:51 AM
  #7742
wtcc's Avatar
Originally Posted by Potoczak
Wtcc what servo mount is that??
That is Yokomo part B7-203.
Also how did you attach the turnbuckle to that bellcrank?
Instead of fixing the part for the Ackermann setup with the button head screw, you use a ballstud and attach the servo turnbuckle on it.
Is that that stock single one in the picture??
Yes!
wtcc is offline
Old 10-21-2012, 08:58 AM
  #7743
Potoczak's Avatar
Trader Rating: 120 (100%+)
Yes!
Got it thanks for the info!! Where is the best place to get that mount??
Potoczak is offline
Old 10-21-2012, 09:02 AM
  #7744
wtcc's Avatar
I bought it in Austria
Mmmh, better ask in the Yokomo BD7 thread...these guys should know best!
wtcc is offline
Old 10-21-2012, 09:12 AM
  #7745
does it change the feeling in the steering anything or is it the same?
Bappe is offline
Old 10-21-2012, 09:22 AM
  #7746
JustWill75's Avatar
I would like to know the same.
JustWill75 is offline
  #7747
wtcc's Avatar
I felt no difference.
I made it for two reasons: 1. to have more space for my electronics and 2. to equal weight distribution symmetrical on both sides.
wtcc is offline
Old 10-21-2012, 09:31 AM
  #7748
sounds good
would be nice to have some more room for the electronics, especially when running a futaba receiver!
How is the new wc chassi, what benefits does it have in handling compared to the old one? (other than being more narrow)
Bappe is offline
Old 10-21-2012, 02:45 PM
  #7749
KC10Chief's Avatar
Check out my latest Indoor Setup from Senden on PetitRC. Did a just for fun run with foam tires (26mm front and rear) and the car was even more awesome! You can't follow the car with your eyes so fast! I think I even broke the lap record
@Michael: I had to drill one hole in front of the forward hole.
Thanks! I'll start with that. Up here, they are racing 26mm foam tires front and back.
KC10Chief is offline
Old 10-21-2012, 04:53 PM
  #7750
Trader Rating: 77 (100%+)
These cars are the best. Out of it for a couple years. Picked up a 6.1, added all the WC bits minus the chassis and ran it today for the first time. Right out of the box this thing rocks. Handled awesome and so fun to drive.
goin2drt is offline
Old 10-21-2012, 07:37 PM
  #7751
Hi Guys,
I have a question regarding the spur and pinon size on the tc6.1. I have mounted a silver can (Tamiya 540) motor and I faced the same problem of the bushing and the screws not lining up so added a stack of washers upto 5mm as spacers and I have installed the motor but I have a 72t 48p spur gear and I have 24, 25, 26t pinions and non of them touch the spur gear So I need to buy a bigger spur gear and around 3 pinions.
I am looking at the following spur pinion sizes :
Spur-pinion = drive ratio
81-31 = 5.22
81-30 = 5.40
81-29 = 5.58
81-28 = 5.78
87-33 = 5.27
87-32 = 5.43
87-31 = 5.61
87-30 = 5.8
What combination should I get, any suggestions ?
I am very new to racing and still learning to drive so I am looking at a 5.7 ratio to start with ...
Thanks.
FourWheels is offline
Old 10-22-2012, 01:24 AM
  #7752
ScottyTC4NZ's Avatar
Originally Posted by FourWheels
Hi Guys,
81-31 = 5.22
81-30 = 5.40
81-29 = 5.58
81-28 = 5.78
87-33 = 5.27
87-32 = 5.43
87-31 = 5.61
87-30 = 5.8
Thanks.
Hi,
Really depends on what your track is like i.e. long and flowing, tight and twisty, also depends on the tamiya 540 motor you have.
Our Track is a mixed track and some guys are running from 3.3-4.17, just depends on your motor.
hope this helps, any further questions I will try and help
ScottyTC4NZ is offline
Old 10-22-2012, 01:38 AM
  #7753
rbarciko's Avatar
The tc6.1 manual shows what spur/pinion combinations will fit:
Beginners at our track need to use a ratio of 6.1 or higher, so you can use the 87 or 80 tooth spur with the appropriate pinion with the Johnson / mabuchi 540 silver can motor as shown above.
Then when you want to go faster, you can go back to your 72 tooth spur with a 36-41 pinion, but not lower than 3.50 ratio, as the brushed motor will burn out quickly.
After that you will need to look at investing in a brushless motor / esc, eg. 21.5 turn, depending on the classes at your local track.
I'm still racing with my 540 silver can motor, so I use the Spec-r motor heat sink (instead of using washers/spacers which is a hassle):
https://www.tqrcracing.com/shop/prod..._id=&cart_seq=
and have the complete set of yeah racing 48 pitch pinions - 21t-38t:
http://www.tqrcracing.com/shop/produ...id=59&s_sort=5
rbarciko is offline
Old 10-22-2012, 03:36 AM
  #7754
Just1More's Avatar
Just throwing this out there but since my LHS had no battery tape, we used a Losi 22 battery strap(velcro), cut the plastic end off the loop and slid the carbon fiber battery hold down piece through the loop.
Can someone verify it though? Don't take this to be gospel just yet, he had it in the back and said it was from a 22. From the pics the 22 strap looks too short. Spektrum makes long ones also(found on Amain)
Just1More is offline
Old 10-22-2012, 05:41 AM
  #7755
rbarciko's Avatar
I've used the Yeah racing Velcro battery strap for 6 months and it works fine, however under hard impact from the opposite side I have had the battery pop out a few times:
http://www.tqrcracing.com/shop/produ....asp?p_id=2531
Which is why I've now upgraded to the Reflex battery hold down system:
http://www.reflexracing.net/RSD-AE-T...em_p_1300.html
rbarciko is offline
