Team Associated TC6 Thread >
Like Tree20Likes
Old 10-08-2012, 04:12 PM
  #7576
hyperdrive1's Avatar
Originally Posted by Flagler
Hey guys. What's the best way to gain some rear grip? I'm running on carpet with solaris medium tires. I have the oil at 30 in the rear with green springs. Everything else is kit setting. I'm looping it and the end of the straight and back end is stepping out in every corner to the point that I cannot drive it. I have some guys who are going to help me at the track next weekend, but if I can go in with the right setup (or close to it) it might make things easier.
You didn't mention anything about tire sauce?....Last week on our carpet track, I only sauced half of the back tires and it was real loose...sauced all the way across, problem solved?....just throwing it out there.
hyperdrive1 is offline
Old 10-08-2012, 08:04 PM
  #7577
JFuel11's Avatar
Trader Rating: 152 (100%+)
Default Need a little help please...
I am making the switch from offroad and back to carpet onroad and need a little setup help please...
What would be good starting setup on new chassis buildup for 32'x72' carpet track... Plan to run Jaco Blue tires and this will be for 17.5 class as they don't have a mod class going yet.
Key things I need please:
Starting 17.5 gearing (Ballpark...)
Chassis Setup
Body...
Any help is greatly appricated.
JFuel11 is offline
Old 10-08-2012, 08:45 PM
  #7578
chevtech23's Avatar
FDR probably in the 3.8 to 4.0 range
Kit setup is a good starting point, to get an idea of what the team guys are running look here:
http://www.teamassociated.com/setupsheets/TC6.1/
Protoform Mazdaspeed 6 body is a good balanced body for carpet.
Welcome back
Chassis Setup
Body...
chevtech23 is offline
Old 10-09-2012, 11:22 AM
  #7579
Rick Hohwart's Avatar
Default New setup posted
Mike Haynes - IIC 17.5 Stock
Rick Hohwart is offline
Old 10-09-2012, 11:34 AM
  #7580
Are the set screws for CVD's really necessary? The metal retaining ring seems to do a good job at keeping the pin in place.
jha07 is offline
Old 10-09-2012, 11:40 AM
  #7581
mtbboy's Avatar
Mr, Hebert gave me a quick tip that I had not considered.
Tc6.1 arms.
Grind the area where the spring retainer meets the arms.
Just enough so they dont rub in all arm positions.
I had been struggling with chassis tweak, shock lengths, weight balance etc only to find that the retainers were not allowing the shocks to work freely.
Small pointer = huge relief in frusteration.
Just wish I had done this in Vegas and not at home.....Oh well next year
Just posted 4 Mains from the iic on you tube.
Channel= DaveChen.
mtbboy is offline
Old 10-09-2012, 12:37 PM
  #7582
Originally Posted by Rick Hohwart
Whoa, silver front and blue rear spring?
-Mike
grippgoat is offline
Old 10-09-2012, 12:54 PM
  #7583
-Mike
That's what I was thinking. What's up with the DCJ's in the rear, too?
Serzoni is offline
Old 10-09-2012, 01:41 PM
  #7584
I'm gonna say there reflex springs with those colors
Jeff Cuffs is offline
Old 10-09-2012, 02:56 PM
  #7585
geeunit1014's Avatar
Trader Rating: 14 (100%+)
Blue is still harder than silver in reflex. Haynes was playing around with the AE silver front blue rear spring combo when he came down to MRH to test.
The DCJs in the rear is a feel he likes. It makes the car really rotate in the middle of the corner out. When he came to MRH (my home track) to test, I tried it, but I didnt like the feel of it, and was faster with the standard axles in the rear.
geeunit1014 is offline
Old 10-09-2012, 03:47 PM
  #7586
oladele's Avatar
what do you guys think of the TC6.1 worlds car?
http://www.teamassociated.com/cars_a....1/Worlds_Car/
upgrades
http://www.teamassociated.com/news/l....1_Worlds_Car/
oladele is offline
Old 10-09-2012, 05:25 PM
  #7587
Originally Posted by oladele
will be getting that chassis plate as soon as its for sale!
Edwin Pibal is offline
Old 10-09-2012, 06:25 PM
  #7588
Mike Haynes's Avatar
-Mike
Yes that is acurate, you will notice the rear is laid all the way down, when you press the car on the board it feels "normal", it helped carry the car well in the small sweeping corners
The dcj in rear let the car "float" on the track, it is an acquired taste, but i posted exactly what was on the car.
My stock car has AE springs.
As Mike mentioned my car may not be what your used to driving, but i have used this setup for the last few months and it has been decent on any track i have been to, small tweaks like camber link shim and swaybar are all i really change.
Mike Haynes is offline
Old 10-09-2012, 06:28 PM
  #7589
Tc6.1 arms.
Also make sure your rims are not rubing, i shave the lip on the arms as well just to be safe.
Old 10-09-2012, 08:48 PM
  #7590
mtbboy's Avatar
I will do that also Mike.
A pleasure meeting you as well last week.
Between you ,Other Mike and Mark I cried laughing a couple times forsure. No punches pulled between you guys.
Next year.
D.
mtbboy is offline
