Team Associated TC6 Thread >
Like Tree20Likes
Old 09-20-2012, 03:39 PM
  #7441
mtbboy's Avatar
Originally Posted by racer_hh
May somebody help me on finding the right ratio (as mentioned some posts before).
TC6.1 13,5t engine and carpet track. What spur gear / engine pinion should I take.
Start with a 4.5 Fdr for blinky and go up or down based on motor temp.
Aim for a temp of 170-180 after 6 mins with a fan.
D.
mtbboy is offline
Old 09-20-2012, 04:34 PM
  #7442
YoDog's Avatar
Trader Rating: 28 (100%+)
Ok, if you are running a "blinky" class which is what I gather from your earlier post, you should get a 96t 64 pitch spur gear. You should then have 36t-44t pinions that will give you a tuning range of 4.36 through 5.33 FDR.
Find out what other drivers are running at your track and use the right pinion to get close to what they are running.
If you intend to race on a regular basis, you will need to purchase a reasonable set of gears to find the right combination for different track conditions and locations. There are too many factors that go into selecting the perfect gear ratio so its always best to have some choices.
If you know what the intended FDR (final drive ratio) is, you can usually find the combination to get you there. If you don't have a FDR calculator, there are plenty of resources available. just google it...
YoDog is offline
Old 09-21-2012, 12:11 AM
  #7443
Thanks a lot!
That's a good basis now.
racer_hh
racer_hh is offline
Old 09-21-2012, 01:57 PM
  #7444
Rick Hohwart's Avatar
Default New setup posted!
Olly Jefferies - BRCA Rd. 5 Mendip
Rick Hohwart is offline
Old 09-21-2012, 02:43 PM
  #7445
Originally Posted by Rick Hohwart
Rick,
for future, all is fine in this setup but hpi silver and blue says nothing for me.
how many LBS for that springs? they are compare to ae something?
just my 3groszy
M.Abramowicz is offline
Old 09-21-2012, 03:45 PM
  #7446
The pound rating won't matter. Two different springs can both be 15lbs, but if they're wound differently, they'll have a different feel. He ran HPI springs, so that's what's on the setup sheet.
Serzoni is offline
Old 09-21-2012, 03:55 PM
  #7447
Originally Posted by M.Abramowicz
Rick,
just my 3groszy
The closest thing AE is silver all around.
Old 09-21-2012, 04:11 PM
  #7448
CristianTabush's Avatar
HPI Silver is a 16.2-16.5lb spring. HPI Blue is a 14.4-14.6lb spring.
It's like running RSD Purple and RSD Blue.
CristianTabush is offline
Old 09-21-2012, 08:12 PM
  #7449
I'm sure it's been asked before, but nothing really came up from my search.
What spare parts are good to have on hand for the TC6.1?
jha07 is offline
Old 09-21-2012, 08:54 PM
  #7450
Knuckles and caster blocks. Maybe some spare suspension mounts in the event of crazy collisions. Also, some spool cups and blades.
Aside from that, the car is pretty tough.
Old 09-22-2012, 05:52 PM
  #7451
Thanks, that's not too bad. So arms and rear hubs aren't necessary?
jha07 is offline
Old 09-22-2012, 06:47 PM
  #7452
geeunit1014's Avatar
Trader Rating: 14 (100%+)
Not really. maybe grab a pack of them just because, but you wont want/need multiples of them like you would the stuff christian listed. I havent broken an arm or rear hub ever
geeunit1014 is offline
Old 09-23-2012, 07:08 AM
  #7453
rcguy76559's Avatar
Trader Rating: 22 (100%+)
new to onroad seen. picked up a 6.1 will be running blinky class 17.5. Track specs run on is 100ft x 100ft soda prep bumpy low-med grip. So its a tight track do i run spool in front or gear diff in front with really think oil 100000cst. pros and cons
rcguy76559 is offline
Old 09-23-2012, 03:48 PM
  #7454
Chief's Avatar
By blades... Do you mean the out drives? Also, what are the knuckles?
Chief is offline
Old 09-23-2012, 04:14 PM
  #7455
Chaz955i's Avatar
Blades are the plastic pieces that fit over the end of the dogbone that goes in the outdrive. Knuckles are the front steering hubs.
Chaz955i is offline
