Team Associated TC6 Thread >
Like Tree20Likes
Old 03-16-2012, 11:06 AM
  #6241
Originally Posted by ChampRC
Most cars will do that and it has to do something with the driveshafts and how they bend at the joints. Simplest solution would be to lower your EPA percentange on your radio left and right. But that could cause you to lose some steering on certain tracks. All and all I don't feel its really anything to worry about. The CVAs work well and are better than straight dogbones in this matter.
Heres some videos on some solutions.
Xray's "billion" dollar solution lol (ECS drive shafts)...:
http://www.youtube.com/watch?v=S7S95NcOxug
SpecR's universal..:
http://www.youtube.com/watch?v=jETDv...eature=related
Spec R had no solution for TC6. What to do then?
Has Team Associated a solution?
Kensei is offline
Old 03-16-2012, 01:38 PM
  #6242
I don't think AE has a solution yet.
One of the team racers used the Hotbodies DCJS...as seen by the quote below.
Originally Posted by Keven H
I was running Hotbodies DCJS 44mm.
I think these are the parts: http://www.amainhobbies.com/product_...ve-Shaft-Set-1.
I dont know how he got them to fit...
I dont know if theres any clear advantage to these than the stock shafts, does anyone know if these are worth the investment and if they are a direct fit on the TC6?
ChampRC is offline
Old 03-16-2012, 02:09 PM
  #6243
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
Default Video helped out greatly
Thanks for the videos they helped and are exactly what i was talking about!
I'm going to look into both companies!
BlackStarRacing is offline
Old 03-16-2012, 02:29 PM
  #6244
Default battery tape
hey guys you know any hobby stores online thats has the tape for a fair price?
Old 03-16-2012, 03:26 PM
  #6245
Trader Rating: 38 (100%+)
Let's try this again
Originally Posted by or8ital
Can the shock bottom cap o-ring be purchased without the bottom cap?
Or just the size of the o ring?
I bought these...
…they are not the correct size
or8ital is offline
Old 03-16-2012, 04:58 PM
  #6246
JustWill75's Avatar
Does anyone know how he got them to fit?
JustWill75 is offline
Old 03-16-2012, 05:07 PM
  #6247
WillD's Avatar
Thumbs up
Good news!
My Team Associated order shipped out today!
It happened to include some TC6.1 C-Hubs!!!!!!!
WillD is offline
Old 03-16-2012, 05:24 PM
  #6248
cwoods34's Avatar
Reflex Racing should be releasing DCJ shafts in the near future that will drop right in to the 6.1 (will require light Dremeling for old style casters)!
cwoods34 is offline
Old 03-16-2012, 06:07 PM
  #6249
masterhit's Avatar
Trader Rating: 16 (100%+)
The hotbodies dcj fit without modification in the 6.1. Same With the BD5 Spec-R dcj.
Both require the use of Tamiya, Yokomo, or Hotbodies hexes. 5mm will get you stock hex spacing.
If you're running the 3-3.5mm front arm spacing you will need to put a 1mm shim under the spool cup with the Hotbodies dcj.
AE blades can be drilled to fit the HB dcj or you can use the HB blade. The AE blades can be used as is with the Spec-R dcj.
I have used both, the HB joints are the stronger of the two, but a set of Spec-Rs are not much more than 1 HB dcj and are easier to rebuild. I have run the Spec-Rs on carpet with a boosted 5.5 without issue.
Mike Slaughter
masterhit is online now
Old 03-16-2012, 11:52 PM
  #6250
Mike Slaughter
Do you need the elusive 6.1 caster blocks to fit the DCJs?
Steve S is offline
Old 03-17-2012, 01:29 AM
  #6251
I bought these...
Just so im sure, you mean the o rings here ?
http://www.amainhobbies.com/product_...et-w-O-Rings-2
I havent seen the orings by themselves
Edwin Pibal is offline
Old 03-17-2012, 01:36 AM
  #6252
Correct. Those o rings.
or8ital is offline
Old 03-17-2012, 08:52 AM
  #6253
cherokee95's Avatar
Grab a caliper. Then look here, metric o-tings are to the right. I would imagine they have the size you need. It is lame that they are not sold separately.
cherokee95 is offline
Old 03-17-2012, 04:41 PM
  #6254
Big Features's Avatar
From the CARPET NATS:
Rick Howart is TQ in MOD touring with Keven Hebert right behind.
Sean Cochran is TQ in Blinky stock
Mike Blackstock is 2nd in 1/12th Mod
"Give'm da business, Boys!!"
Big Features is offline
Old 03-18-2012, 05:27 PM
  #6255
JustWill75's Avatar
ok so how did we do?
