Team Associated TC6 Thread
#2328
Chris, have you seen my Thread? Our springs approximate the XRay springs very much, except they fit much better on the AE shock.
The Xray C2.8 springs are 16 lb springs and the C2.6 are 14.82 lb springs. With the long links it is just about perfect. With shorter links, like I run on our vertical-stud bulkheads, I went slightly softer to a 13.5lb rear and a 15.5lb front spring.
Give the A3 a shot, you'll find that you don't need to re-tighten the arms after every run anymore. Good place to start on the outside is with 4mm underneath the outside stud in the rear and 2mm in the front, with the extra long links (7 hole).
#2330
#2332
Thank you... much appreciated
#2334
Yes, I looked at those (since I have a XXXT-CR & XXX-SCT)... but wasn't sure if they would cause any problems as they are slightly thicker than the AE pistons, but they do indeed fit the shock shaft and their diameter seems to be spot on.
#2338
I got mine out on Saturday and it's sweet! No breaks no hickups, and it was stuck compared to others out in early season conditions. I highly recommend these few options.
Setup with tons of steering and asphalt traction.
http://www.teamassociated.com/pdf/ca...rnats_2011.pdf
Losi #57 shock pistons (3 hole instead of AE 2 hole)
http://www.losipartshouse.com/servle...2357%2C/Detail
Diggity Designs 6 deg. castor blocks--will not break.
http://www.diggitydesigns.com/D3_TC5...rBlockSet.html
You can thank me later.
#2340
Excellent JayBee!!
