Team Associated TC6 Thread >
Like Tree20Likes
Old 12-03-2010, 11:26 PM
  #826
I have just finished my Tc6 build and have a 6 screws missing and 2 of my Roll-bar ballstuds did not have the Hex in them !
A little dissapointed with a kit of this price bracket.
Shock are a major major improvement over the Tc5's and i'm so happy now i have more electronics space.
I just hope the car drives better than it built !
tc3nitro is offline
Old 12-04-2010, 07:33 AM
  #827
Here's a couple of pictures of my complete car ! Sorry about the quality the camera was just about to die!
tc3nitro is offline
Old 12-04-2010, 07:55 AM
  #828
Does anyone else have problems viewing the PDF's from the AE site with a Mac or iPhone ?
All the PDF's are missing pictures and sections....???
tc3nitro is offline
Old 12-04-2010, 08:02 AM
  #829
They work on my Mac book pro!
DJG24 is offline
Old 12-04-2010, 08:05 AM
  #830
Ummmm
Thats strange !
I can't get them to work on my iMac, MBP or my iPhone....??!?
Weird !
tc3nitro is offline
Old 12-04-2010, 08:11 AM
  #831
I get them on my phone too but I have an Android phone.
I must say, I like the car but there were a few things I was not thrilled with. I dont care for the tiny 2.5mm screws that hold the spur in. I think its more of a problem with the aluminum shaft that they screw into. Seems hard to get them out and change spurs. Also my center pulleys would not fit all the way onto the spur adaptor. when I popped the e-clip in to hold it together the whole assembly got real tight. Had to do a little resizing to get it free.
DJG24 is offline
Old 12-04-2010, 08:27 AM
  #832
twk-b's Avatar
Default whats the deal with the 1 off side hole?
Hey Keven,
Finally got my 2 TC6 cars... got one build and running last night with something close to your setup on it. The only real difference currently is I am running Losi #57's instead of your custom piston inserts.
Thanks for the fantastic starting point!
I just got the blank inserts I ordered and I am going to try some of your 1x1x1.5mm deals next week to see the difference..... BUT I was wondering what the logic is behind running the different sized holes in that configuration, rather then making all the holes evenly sized (like half way between @1.25mm), or a configuration with 2 holes of each size....
Wouldnt the difference in flow/pressure cause the piston to bind with its preference to the biggest holes side?
What should I notice in comparison to the Losi57s?
Thanks again for sharing all this great information,
-b
twk-b is offline
Old 12-04-2010, 09:05 AM
  #833
Trader Rating: 40 (100%+)
Default RE:overall shock length
Anyone has any idea what the overall shock length should be?
joech is offline
Old 12-04-2010, 11:33 AM
  #834
Tbizz's Avatar
Yeah...I'm having that same problem on an iPad. It looks as if it's viewing an indd file instead of a PDF for some reason.
Tbizz is offline
Old 12-04-2010, 11:59 AM
  #835
Johnny Wishbone's Avatar
Say it isn't so Joe.
Blue of a different colour.
Johnny Wishbone is offline
Old 12-04-2010, 12:08 PM
  #836
Mine are 61.7mm with the ballcups threaded all the way in to the shock shafts
Fastfreddy74 is offline
Old 12-04-2010, 05:16 PM
  #837
Originally Posted by twk-b
Hey Keven,
-b
- Hi,
I have been running these piston since the last asphalt race we had at a very high grip track.
To me it felt like those pistons did not let the car roll as much as a 57 althought on the bench it actually feels like a 56. It packs more and when the grip is high, it seems to make the car a little more responsive and easier to drive.
Hope this helps
Keven H is offline
Old 12-04-2010, 09:45 PM
  #838
ira
ira's Avatar
Trader Rating: 18 (100%+)
Started my build Friday night and hoping to complete it by Saturday night to race on Sunday. I ran into a little problem, one of the holes on the bulkhead (one that is mounted to the chassis) is drilled and taped to big, you can push and pull the 3mm screw in and out of the hole. The second thing was one of the CVA coupler hole was not drilled straight, when I tighten the set screw on the CVA cross pin, it binds on the CVA Bone.
The rest of the build went together just fine, looking forward to racing the NEW car!!!
ira is offline
Old 12-05-2010, 06:46 AM
  #839
I was not running these pistons until the indoor champs. I will say that this combo works very well with high traction. I was skeptical at first thinking how could one hole make a difference, But then i did it and put the car on the track and the car felt like it stayed flatter and was easier for me to drive, I picked up almost .1 or more per lap with this change alone over losi 57's.
Right now i am very happy with the car, Since i have not been running TC very much let alone rubber tires, to post the same fast laps as keven and paul but with more mistakes on my part lol, Tells you the car is very good. I hope to get better and be able to compete with them very soon.
Mike
Hey Keven,
-b
Mike Blackstock is offline
Old 12-05-2010, 08:02 AM
  #840
t4mania's Avatar
Anyone have a P/N for the blank pistons so I can drill my own.
t4mania is offline
