Team Associated TC6 Thread >
Like Tree20Likes
Old 12-13-2012, 02:39 PM
  #8326
DesertRat's Avatar
Originally Posted by geeunit1014
Your setup is a lot different than what most of us would run. My suggested changed is red above. It seems like the rear of your car is extremely soft, which will let the car dump over in corners and become very loose. The front of the car is extremely stiff, which is probably an adjustment for the rear, but it just makes the front end wash out probably. Those changes should get you more in the ballpark of how I know the car likes a setup on carpet.
I'll give it a shot,
Its amazing how you can ask two different touring car guys a question and get totally opposite suggestions. All I know is that I have been all over the map with this car and it didn't get better.
Hey Team Associated: WHY IS YOUR KIT RECOMMENDED SETUP SO TERRIBLE AND SO DIFFERENT FROM WHAT ANY TEAM DRIVER ACTUALLY RUNS ON ANY SURFACE!!!
DesertRat is offline
Old 12-13-2012, 04:27 PM
  #8327
DARKSIDE's Avatar
I run for AE, and Im very happy to say that the manual setup has worked very well for me on multiple tracks across the US...incl winning me the Snowbirds National title in Amature 17.5 TC and 2nd place in VTA...as well as many regional titles across the Southeast and northern states incl USVTA Scale Nats at The Track Harbor Hobbies taking TQ and finishing 2nd in a 20 min A-main(1st time in 4 years)
You might try again to put the car back to the manual setup and start over. Make sure all the shims and belt cams are in the right place. Then start to make very small changes.
The only changes Ive made is to camber(for traction) and motor timming.
The car will work for you, just take a little time to make small changes to it to get it like you want.
ps..I run the "boxstock" setup, cause I like a very neutral feeling car, alot of the other AE drivers setups dont work for me. Doent mean they wont work for you.
Hope you get it setup like you like...
Attached Thumbnails Team Associated TC6 Thread-img_20121006_191744.jpg   Team Associated TC6 Thread-photo.jpg   Team Associated TC6 Thread-snowbirds_2012_sunday_964.jpg   Team Associated TC6 Thread-2012_scale_nationals_flier.jpg   Team Associated TC6 Thread-img_20111016_093116.jpg
DARKSIDE is offline
Old 12-13-2012, 05:02 PM
  #8328
Monsta's Avatar
+1 to the above (and geeunits setup tips)
i run/ran in VTA (hard hard tyres) on a low-med grip asphalt outdoor cct. as the car has fairly close to 50/50 weight i ended up running a softer setup up front.
Front -AE greens front/35wt oil/reflex 1x1x1.5 pistons (spool)
Rear -AE silver /35wt oil/reflex 1x1x1.5 pistons rear (Gear diff)
soo predictable and has a huge amount more of turn in to when i ran harder springs in the front.
Monsta is offline
Old 12-13-2012, 05:06 PM
  #8329
BLKNOTCH's Avatar
Thank you for this info, I am going to be setting up my first VTA ride ever and am looking for asmush VTA info as possible for my TC6.1
Spur and pinion idea's?
BLKNOTCH is offline
Old 12-13-2012, 10:28 PM
  #8330
geeunit1014's Avatar
Trader Rating: 14 (100%+)
Touring car setup is very much predicated on how you drive, how you manage the traction the tires have since the grip from rubber tires isnt a lot. I do think you will like those changes a lot more than what you had though
geeunit1014 is offline
Old 12-13-2012, 10:29 PM
  #8331
Trader Rating: 27 (100%+)
Gee-approved!
MDawson is offline
Old 12-14-2012, 01:10 AM
  #8332
Originally Posted by wtcc
Unfortunately you are right
Also these things break if you just look at them, because of a wrong calculated tool... I really think about using alu c-hubs. Right now I use my old tc5&6 spare parts.
yes
I have allu ones and they sucks more then plastics, more slop ...
and they break a-arm mounts or a-arms on small hits ...
they just need slighty tighter kingpin...
M.Abramowicz is offline
Old 12-14-2012, 03:23 AM
  #8333
Monsta's Avatar
No worries mate. The pinion/spur will really depend on the track, best bet is to see what the guys are running at your's
For example, we have quite a large track/long straight (3 netball courts) so I ran a fdr of 3.00, 42/63
Monsta is offline
Old 12-14-2012, 05:15 AM
  #8334
Team Grid RC's Avatar
Originally Posted by YoDog
So... Would it be accurate to say there is a market for a direct fit, floating servo mount for the TC6?
Perhaps I will work something up that folks would be interested in. I like the 3 piece design like the Xray.
Ours is a direct fit and have been available for some time now. Unless you want something different.
Team Grid RC is offline
Old 12-14-2012, 10:52 PM
  #8335
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
For those considering the new lightweight axle shaft dont waste your money, they are crap, blades arent even straight with the pin and dont even fit the ae axles as stated. They dont fit because they dont have the flat cap spot at the end like the ae ones.
http://www.tqrcracing.com/shop/produ....asp?p_id=3290
axles stuck
blades fit crooked
Mr.juarez is offline
Old 12-14-2012, 11:53 PM
  #8336
Any Picts of it installed? Does it still mount the servo the stock way, just floating, or does it reorient it to across the chassis instead of inline?
Vostok 7 is offline
Old 12-15-2012, 12:47 AM
  #8337
rbarciko's Avatar
With the grid rc servo mount, the servo is in the standard position (front/back):
http://www.redrc.net/2012/08/team-gr...n-servo-mount/
rbarciko is offline
Old 12-15-2012, 07:42 AM
  #8338
After testing both mounting positions on the TC6 we have found no difference in performance. Both methods float the servo, connect to the steering bellcrank at 90 degrees. The WC kit still has the stock servo mounts.
Sideways mounting the servo give more space only if you run a low profile servo.
All the settings and tuning you do to the TC6 is of no benefit if the chassis won't respond to it. The two heaviest components, servo and battery needs to float.
We already showed racers how to float the Lipo battery. http://www.rctech.net/forum/11071986-post29.html
The floating servo mount we made is a direct mount and if you do these two things to the servo and battery, you will notice big handling performance. Also lock the servo saver further.
We have talked to several racers and they did tell us drilling holes, and then have to countersink them to use a sideways mount (by-passes stock servo saver and requires a servo saver on servo) and in the end not gain more performance over the floating stock orientation would not be the way to go.
Thus we came out with our mount. It is low cost and takes minutes to install. The battery mod also takes minutes and is free.
Old 12-15-2012, 11:44 AM
  #8339
Really like your mount - do you ship to the uk if I order through your web site?
scoyle is offline
Old 12-15-2012, 12:26 PM
  #8340
We ship worldwide. We already have many racers using these mounts in UK, Sweden and Australia.
