Team Associated TC6 Thread
#2356
As for anti-squat i don't think anyone measured that in degrees or maybe the relevance of that. As for camber i really don't understand your question, camber gain?
#2357
The 3B link position will give the same camber gain as 3A, but the roll-centre will drop more as the car corners (due to the longer links). This will give more mid-corner rear end grip. It will make the car feel a bit lazy, but is useful in low grip conditions, or on big flowing tracks where you don't need quick direction change.
#2358
Excellent JayBee!!
I got mine out on Saturday and it's sweet! No breaks no hickups, and it was stuck compared to others out in early season conditions. I highly recommend these few options.
Setup with tons of steering and asphalt traction.
http://www.teamassociated.com/pdf/ca...rnats_2011.pdf
Losi #57 shock pistons (3 hole instead of AE 2 hole)
http://www.losipartshouse.com/servle...2357%2C/Detail
Diggity Designs 6 deg. castor blocks--will not break.
http://www.diggitydesigns.com/D3_TC5...rBlockSet.html
You can thank me later.
What keeps the aluminium caster blocks from bending and changing your caster/camber without it being obvious?
#2359
#2360
As for the relevence of the degrees. Does the greater the anti squat angle stiffen the rear?
#2362
That setting should give you about 1.7 degrees of antisquat. The difference in height is about of the blocks 1.5mm so, if you do the math, that's the number that comes up.
With all the mounts, the difference is 1mm increments. It is just when you go from B0 to A3 that you get a 1.5mm change. So with all the other mounts, when you use anti-dive, anti-squat, pro-squat, or kick up, the change of going 1 block different in any direction is 1.15 degrees. Only when combining A3 with B0 will you get 1.7 deg.
#2363
I ran a set for not very long (because it was all I could buy), and the other people I have seen running them, they were warped... They will let you finish the race/weekend but they just bend instead of breaking....
-b
#2364
I retrofit a Parma T2 bumper and the front end is rock solid. No need for Aluminum parts...
I use Aluminum parts as a tuning option. As grip comes up sometimes it is nice to try out more rigid steering components.
#2366
ahh.. i didnt do all the reading back but assuming this is tc5/tc6 related my two cents would be.... having a set of the aluminum ones in your parts bag would be good for when u have busted all your plastic ones on the "wall of champions" (and there are none on the shelf at the LHS)....
-b
-b
#2367
Excellent JayBee!!
Vern, did you use this setup at fantasy world? Did you deviate from the setup at all. Unfortunately, I don't have access to HPI stuff.
#2368
Only changes I made were steering bellcrank at 7B instead of 7A, Losi #57 shock pistons (3 hole), springs AE silver, silver, 60 wt oil in front and 40 in rear.
Nothing HPI on mine, the AE springs are fine IMO. If you look at the "Olly" setup which is similar those changes I listed were run by him as well.
#2370
sloppy
I have never seen so much slop in a touring car.
So I changed to a new arm and Chub, and its still sloppy.
The bores for the front arms are just too big for the hinge pin.
I might just need to drill a hole in the Chub and use a set screw to hold the hinge pin, hopefully it will get rid of the slop.
