Team Associated TC6 Thread >
Like Tree20Likes
Old 04-20-2011, 06:54 AM
  #2296
Shock pistons are #1(54) #2(55) and #3(3/64")
Kit springs are silver (14.5 lbs) and green (12.0 lbs)
Sway bars are both 1.25mm and the internal gear ratio is 2.0:1
Fastfreddy74 is offline
Old 04-20-2011, 06:56 AM
  #2297
olhipster1's Avatar
Trader Rating: 102 (100%+)
Originally Posted by goin2drt
I have my kit coming. Can anyone tell me what shock pistons come in the kit as well as what color of springs?
Thanks.
you get a full set of pistons...
1, 2, 3. AE labels a little different. I'm using the kit #3 and they work great.
i do believe some setups are using Losi 56 or 57...
or drilling out AE blanks to setup is an option.
Springs are Silver / Green if memory serves me correctly.
olhipster1 is offline
Old 04-20-2011, 07:02 AM
  #2298
Trader Rating: 77 (100%+)
Default gearing
Okay pressing my luck. Gearing for 17.5 n/t on high grip indoor asphalt with about a 80 ft straighaway and tight infield.
goin2drt is offline
Old 04-20-2011, 07:25 AM
  #2299
daleburr's Avatar
The same FDR as on any other TC. Why would the TC6 need a different FDR?
daleburr is offline
Old 04-20-2011, 07:33 AM
  #2300
Sorry. Coming from 21.5 now going to 17.5 and was looking for actual gearing suggestions, pinion and spur. Sorry not clear.
goin2drt is offline
Old 04-20-2011, 08:24 AM
  #2301
daleburr's Avatar
You'll certainly need something smaller than the kit spur. This gear chart here shows what will mesh:
http://abram.eu.org/gear_tc6.php
I'd start with your 21.5 gearing and increase the FDR by 0.5 to 1.0.
daleburr is offline
Old 04-20-2011, 09:09 AM
  #2302
artwork's Avatar
Trader Rating: 88 (100%+)
I think this chart is really nice, but it is not entirely accurate...I have been running 31/104 64p and according to this chart that wont fit.
artwork is offline
Old 04-20-2011, 09:12 AM
  #2303
artwork's Avatar
For no timing 17.5 I would try 49/104 64p with an LRP SXX SS V2 V4.4 software.
artwork is offline
Old 04-20-2011, 09:13 AM
  #2304
So is that 31/104 in 17.5 n/t?
goin2drt is offline
Old 04-20-2011, 09:20 AM
  #2305
artwork's Avatar
31/104 with timing with an LRP x12 4dot
LRP SXX SS V2 v4.4
3/3/9/0 was my settings
artwork is offline
Old 04-20-2011, 09:40 AM
  #2306
CristianTabush's Avatar
4.0 FDR with 17.5 no boost is a good starting point. Some people run a tooth higher to range int the 3.8ish range overall.
Basically, run a pinion that is 1/2 the size of the spur, whether 48 or 64 pitch.
CristianTabush is offline
Old 04-20-2011, 09:49 AM
  #2307
jackdani's Avatar
hi guys,
i know that those are yokomo white springs, it is correct??
http://ets.redrc.net/gallery/
if yes, does anyone know which color of the yokomo's is for associated grey and green??
thanks!!
jackdani is offline
Old 04-20-2011, 11:52 AM
  #2308
I am assuming that by gray you mean silver, which is a 14.5 lb spring, this is about equal to Yokomo black. The Green is a 12 lb spring which is softer than what Yokomo offers.
Old 04-20-2011, 03:05 PM
  #2309
Another win for TC6 in Europe:
RedRC news
Setup
jorgesimes is offline
Old 04-23-2011, 12:50 AM
  #2310
on the set up wheres the battery front or rear?
dean-oz is offline
