Team Associated TC6 Thread >
Like Tree20Likes
Old 04-04-2011, 08:26 PM
  #2176
JayBee's Avatar
Trader Rating: 31 (100%+)
I know buddy but you know how anal (thorough) I am about this hobby I'm still a fan of the 'Schmurple'....never had the 'Luxurious One' or Assoc. BLUE. I'll give that a read though...
JayBee is offline
Old 04-04-2011, 10:33 PM
  #2177
303slowdown's Avatar
Trader Rating: 24 (100%+)
Something to think about jaybee. The bulk heads are very soft and bend easily two guys at my track have bent a couple and one of them hardly hits anything also both of them had the big aluminum nut for the servo saver fall off a few times so they lock tighted them other than that the car seems pretty good. I built one of the cars and it went together ok fitment was good.
303slowdown is offline
Old 04-05-2011, 01:17 AM
  #2178
Originally Posted by Scooter79rs
Today I installed a servo where the 'J' horn was really tight but still fit so you may need to find one that is real close and push really hard.
Savox are futaba 25t
Use futaba.
m.
M.Abramowicz is offline
Old 04-05-2011, 01:31 AM
  #2179
Default My setup from ETS/Warsaw/Poland/2011
http://abram.eu.org/files/ets_setup_2011_s.jpg
won mod last lower final
made a lot of mistakes at saturday (drive 2x times in wrong Q group) but it
was fun
I start driving with almost factory setup except:
- silver outer balls with spacers,
- lowered roll center at rear and front end,
- pistones like Keven and thicker oil (little wrong choice).
Now, there is my setup with links like wtcc test at his local track.
And car was easy to drive, fast in corners and only me doesn't use this right
hehehe
Thanks wtcc for this upper links advice, it made car drive so easy
Old 04-05-2011, 02:43 AM
  #2180
wtcc's Avatar
I can't share the experience with the weak bulkheads. I had some real hard full speed crashes into strong walls and not one problem with bend aluminum parts. The plastic parts will give up first protecting the carbon and aluminum (but only if you hit something strong)!
That is my experience with the car since november and a number of races.
wtcc is offline
Old 04-05-2011, 03:43 AM
  #2181
Thanks for you help on the savox and setting it up Rick.
saarnold is offline
Old 04-05-2011, 05:31 AM
  #2182
Same here, my car has been launched into fences a few times and a person, car is still good. I've only removed tweak once. I'm yet to break anything on my car.
Scooter79rs is offline
Old 04-05-2011, 08:13 AM
  #2183
Verndog's Avatar
Trader Rating: 16 (100%+)
Do you know if this issue is more so with the front or rear bulkheads? Looks like in order to keep all 4 bulkheads the same (lower production costs), they allowed the rears to hang out the back when they don't need to (1 mount hole not used in rear). Taking it in the rear, they would take the brunt of the impact. Wouldn't take much to trim those rears back if they are part of the potential problem.
Verndog is offline
Old 04-05-2011, 09:21 AM
  #2184
I am one of the average Drivers that hits the wall once in a while, or maybe more often
So far no Problems with the Bulkheads
However, I killed one Front Bulkhead when a young Kid thought its a real good idea to set his Car on the Track about 2/3rd down the straight just when my 4,5T powered TC6 approached
No chance to react or break.
Luckily the Kid didn't experience any injuries, but I belive he learned the lesson.
On the TC6 the right Bulkhead was dead besides a few plastic parts like Servo Horn, Steering rod eyes, lower steering mount.
Well, i've seen Chassis, Top Decks, Shock Towers and more break on crashes like that. All I can say, pretty reliable the TC6
FrankH is offline
Old 04-05-2011, 10:16 AM
  #2185
It was front bulk heads on both cars ,who knows they might of hit just right or something I'm just sharing what I've seen personaly. As for handling I think the cars are great and work very well. The boards we use are very car friendly (2 1/2 square plastic gutter pipe) and we don't se much breakage.
Old 04-05-2011, 11:01 AM
  #2186
Verndog's Avatar
Thanks for the info....not to be a pain but do you know if they were both motor mount side?
Thanks!
Verndog is offline
Old 04-05-2011, 11:26 AM
  #2187
Thanks!
no each car bent a different side.
Old 04-05-2011, 11:33 AM
  #2188
burgboyz's Avatar
Trader Rating: 70 (100%+)
Mine was bent on right side.
Flyin off the boards into a plywood wall will do that though!
Overall the car has been great and AE has been very helpful!!!
burgboyz is offline
Old 04-05-2011, 11:38 AM
  #2189
Yes i have herd their customer service is great. Personally i have not owned a newer associated car but know many who have and they really like them and if they improved their anodizing i would probably get one but i like all my anodizing to be the same color (and orange lol).
Old 04-05-2011, 09:10 PM
  #2190
SlowPushin's Avatar
Hey this is my first electric car, it will be here on friday and i would like to know if anyone here has the R-spec gear diffs and where can i get them in the U.S, and also what size shims are recomended for use of the R-spec diff.
SlowPushin is offline
