Tamiya TB-Evolution IV >
Like Tree2Likes
Old 10-26-2004 | 09:46 PM
  #1666
Runin Ronin's Avatar
Originally posted by F. Alonso
But...... anyway....... has anyone got the tamiya aluminium drive cups yet??
Hierog and I have a set on their way. I'll post pics when I get them
Runin Ronin is offline
Old 10-26-2004 | 09:57 PM
  #1667
F. Alonso's Avatar
Hmmmmm, they look very tasty!!
F. Alonso is offline
Old 10-27-2004 | 04:58 AM
  #1668
Over here in the UK it is not unheard of for one of the racing mags out there to use PSP and remove your sponsord decals if they do not fit in. I had a pic of my car in the mag this last month and they had all been removed. Thats something to get pissed about not having a pic of some bloody gearbox's stuck on ebay.
Anyhow if dont affect me does it so lets get back to the topic guys.
Rick
Rick Draper is offline
Old 10-27-2004 | 06:12 AM
  #1669
hierog's Avatar
Default aluminum drive cups
not the Tamiya ones, but we've got the front Square cups and the rears are on the way
vic
hierog is offline
Old 10-27-2004 | 07:47 AM
  #1670
If I'm not mistaken R10 will have the Tamiya alu cups today or tomorrow?! That's what I was told, as I have a pre-order with him.
espeng is offline
Old 10-27-2004 | 07:52 AM
  #1671
Ballsie's Avatar
Excellent - I will place an order with them today
Ballsie is offline
Old 10-27-2004 | 07:59 AM
  #1672
Ballsie's Avatar
I have a couple of issue with my car.
1. Cells - I use seperate type cells, i've fitted the two end posts and the "Tamiya" battery bar but the cells seem to move a lot side to side within the slots. Would some foam tape to the bottom of the battery bar help or should I stick something to the inside of the lower deck to prevent them from moving? I tried using the plastic part that fits to the outside edge of the lower deck and the cells fit really well, but they rub on the cups on the prop. shaft.
2. Spur Gear - I'm just using the standard tamiya one, it moves a few mm forward and back - is this normal?
Alan
Ballsie is offline
Old 10-27-2004 | 09:34 AM
  #1673
Rick
The way you describe it, the pic was used as "event coverage". It wasn't used as an "advertisement". Totally different issue. Why do you think the magazine removed the sponsor decals? So the sponsors don't sue the magazine.
Old 10-27-2004 | 09:40 AM
  #1674
F. Alonso's Avatar
Alan
1. The way in which the cells are supposed to be mounted if side x side, is by tape through the holes in the chassis on either side of the slots. If you saw the fully hopped up chassis that Tamiya displayed at the Evo IVs launch, then you would see how that was done.
2. I think that this is normal. I also have a little bit of movement but that shouldn't affect performance as it is like 1mm and that's it, maximum.
Old 10-27-2004 | 09:44 AM
  #1675
F. Alonso's Avatar
It appears as if Surikarn is going to be using the Evo IV at the IFMAR ITSC World Championships. Not confirmed but this is what they suspect on the Team Orion website.
Old 10-27-2004 | 09:53 AM
  #1676
fraz's Avatar
Ballsie,
Take the mounting hardware off and just use reinforced strapping tape to secure your batteries. I tried everything possible to get the other mount to work and it's just not worth it. One good hit and your batteries will fly out and your race will be done. Just make sure to file the bottom edge of the tape slots so the tape won't get cut.
A little front to back play in the spur gear isn't too bad. I was going to shim it all out but have run the car that way many times with no adverse reactions. Loose is faster right?
fraz is offline
Old 10-27-2004 | 10:07 AM
  #1677
fraz's Avatar
Default Need some parts ASAP
I figured I had better send a shout out to you guys since I am in a pinch.
I need to score a couple of Evo IV plastic parts. Specifically I am looking for oneway plastic gears (2+) and ball diff gears (2+). Neither SpeedtechRC nor Tamiya have any in stock. I also need a couple of the thrust bearings.
Please PM me if you can help, thanks.
fraz is offline
Old 10-27-2004 | 11:25 AM
  #1678
Ballsie's Avatar
Thanks F. Alonso & Fraz - much appreciated
The tape is what I use on my TRF 415 anyway.
Ballsie is offline
Old 10-27-2004 | 06:43 PM
  #1679
hierog's Avatar
Default once again
thought this was a pretty good quote for this thread:
"also..if you dont mind.. may i post those pics on the TAOB Racing thread so i can get them to go? ROOOOAD TRIP!"
found on
http://www.rctech.net/forum/showthre...threadid=53583
quoted from Hebiki!
hierog is offline
Old 10-27-2004 | 08:21 PM
  #1680
killingtime's Avatar
Post Tamiya TRF Shocks
I've about had it with AE's version of a shock. I want to upgrade to the TRFs but looking at them on Tower Hobbies page it looks like they are not threaded but use spacers for adjustments, am I seeing things?
killingtime is offline
