Tamiya TB-Evolution IV >
Like Tree2Likes
Old 11-03-2017 | 12:06 PM
  #3601
Suspended
I have some spare TB Evolution IV parts for sale.
Looking for $40 shipped.
PM me if interested.
eComet is offline
Old 01-15-2018 | 12:50 PM
  #3602
Hi, is possible to use 44mm shaft in place of original 46mm?
PS: Anyone have a spare damper (#53571) to sell?
pozhar is offline
Old 01-15-2018 | 06:04 PM
  #3603
Yes if you use the short suspension arms. Or narrower blocks. Or both.
Juan Aveytia is offline
Old 08-13-2022 | 01:44 PM
  #3604
Picked up a used "project" TB EVO 4 that seems to be comprised of a mix of parts. Looking to see if I can finish it off.
Are there more modern top decks and main chassis that are compatible with this?
soulstice is offline
Old 08-13-2022 | 03:59 PM
  #3605
Top deck and lower deck. There are no off the shelf newer parts.
you can however fit the latest TRF arms, adjustable suspension blocks and possibly even the latest gear diffs and spool.
soulstice likes this.
Qatmix is offline
Old 09-05-2022 | 10:48 PM
  #3606
Hi guys: can anybody say what the Tamiya gear diff that fits the EVO IV? Part number please?
F1jet_ is offline
Old 09-06-2022 | 09:44 AM
  #3607
OVA's Avatar
OVA
Question what size bevel gear you need?
EVO4 internal is 2.294 17T /39T bevel gear
EVO5 internal is 2.437 16T/39T
EVO6 internal is 2.50 16T/40T
TB04 is the same as EVO6 gearing
they all fit ,it all depend on what internal drive you are using
ps shimming is required
I would use the EVO5 gearing most common part to find available
https://www.rcmart.com/tamiya-ball-d...wed&order=DESC
jo_er86 likes this.
OVA is offline
Old 09-07-2022 | 08:43 AM
  #3608
Thanks, good info.
Has anybody swapped their EVOIV ball diff for gear diff? If so, from which car did you get the gear diff (TB03/04/05 or EVO5/6/7?)
F1jet_ is offline
Old 09-07-2022 | 11:44 AM
  #3609
Papi is offline
Old 09-09-2022 | 08:00 PM
  #3610
Originally Posted by Papi
This article might be useful
https://www.thercracer.com/2014/07/t...art-1.html?m=0
They used TB04 gears, but TB03/Evo5 spool gears should be more or less the same, spool might fit even better.
Thanks, that was a good reference.
F1jet_ is offline
