Tamiya TB-Evolution IV
#1516
Originally posted by KilRuf
The Evo IV may be stiff enough for rubber tire carpet. But not for foam tire carpet. It flexs way too much.
#1517
Originally posted by jeffreylin
My friend busted his steering plate as well but he was bashing on the street and it hit the curb.
#1518
I tried my Evo on the carpet yesterday and it seemed pretty good. My only complaint is that the steering throw is very uneven. I put the servo saver on so that the pillow ball is 90 degrees up, but the actual tire throw is 24degrees to the right and 19 degrees to the left. If anyone knows how to remedy this It would be greatly appreciated. Also what is a good base steering throw for a Touring car with the dual rates at 100%. I have never had this problem with my Xray or TC3, so I'm kind of in a jam.
#1520
I've tried moving the servo horn (stock tamiya servo saver) one tooth over but, it makes the problem even worse. When I move the horn even one tooth the position of the ball link moves 15-20 degrees from the previous tooth. I've gotten the car setup where I have the trim set at 17 steps right from center to even out the throw somewhat. Even with this I only get 19 degrees right 24 degrees left. Yesterday when I tested my car I was getting 32 degrees left 16 degrees right.
#1521
let it roll, adjust the length of the steering linkage (the link between your servo and the steering rack) to center your front wheels. radio is only for fine tuning.
#1522
Droop
Anybody have some setups for mod carpet and/or pavement? Mainly I wanted to get an idea of what droop settings you guys are using. I would also like to know exactly how you are measuring droop. The rear arms it is pretty obvious at the lowest point of the arm. On the front arms is everybody measuring the lowest point (screw boss that sticks down beneath the arm) or the bottom of the arm?
I tried 4mm front and rear in stock and 19t on the pavement but I still felt like the car had too much roll. Anybody else see this too?
#1523
#1524
Hi,
I currenly run a TRF 415, but I'd like an EVO IV too just to try it, especially on low grip tracks like wood surface.
Can you get a conventional front diff (from Tamiya) for the EVO IV?
Cheers.
Cheers.
#1525
EVOtech, yes... traction is much higher with foam tires on carpet. It seems to be a USA (eastcoast/midwest/northern) thing. I'd prefer to race with rubber tires, but I don't live in California.
As for the steering thing. I try my best to set the linkages so that everything is centered when the wheels are straight with radio is on. Then I make sure my Dual Rates are at 100%. Then I adjust my EPA (end points) to make the servo throw end right when it reaches lock to lock. Do this to the Left as well as the Right. Then you can turn down the Dual Rate to 80-90% and go from there. My car always turns equal to the right and left.
#1526
Front and rear diffs are the same... so Yes. You can even use the Evo III diffs. Just swap out the diff gear for an Evo IV diff gear. Then shim accordingly.
#1527
Thanks for your reply - that's excellent, I feel that even the 415 with the yokomo mod diff doesn't feel right on low grip tracks.
Now where's that visa card
#1528
Where can I get Carpet setups for this car? I tested it out this weekend with my steering delema solved, but something just doesn't feel rite. I think the Sponsored drivers should post some of there carpet setups. I think with the proper tune this will be a great car.
#1529
Anyone got a scanned copy of the EVO IV instruction manual that I could download?
Could you post a link to it on the forum or e-mail it to me?
I have checked tamiyaclub.com but it's not one of the manuals they have.
Thanks!
Thanks!
#1530
Let it roll not too many factory drivers who drive carpet in the US. As far as a set-up I have started with stock and gone from there but I have hardly any time on the car I have basically stiffened the springs and been testing tire compounds more than changing the suspension.
The car has felt strange on carpet way too planted. Martin should be finishing up with Worlds in a few weeks here and you should have some more feedback there also.
Cheers
Cheers
