Tamiya TB-Evolution IV >
Old 01-11-2005, 03:16 AM
  #2416
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default Camber
Front: -1.5 to -2
Rear: -1 to -1.5
Hebiki is offline
  #2417
F. Alonso's Avatar
Originally posted by cooliomojo-CEBU
hey great! im sure that you are driving really well with the car. yep, the car has a lot of steering. i would like to beat the others too. im planning to win the race this weekend!hehehehehehe
on another note, have you had any speedo problems before? it seems that i do not get enough punch out of my speedo.....maybe im just paranoid. im using a gt7. you?
Also using GT7. Speedy has plenty of punch and I don't seem to lack punch compared to others. It could simply be your batteries, I don't know. What profile are you using?? Lately I've been racing Stock so I am using 5 at the moment. I will finish up with Stock I think in a few weeks and focus 100% on Modified.
F. Alonso is offline
Old 01-11-2005, 03:21 AM
  #2418
F. Alonso's Avatar
Originally posted by BrainTeased
hey simon
do you use the inner hole on the front hub carrier for steering? i did that and it gave me instantly 5-10 more deg of steering throw! i also had to set my TX for 100% on right hand turns and 72% on left hand turns as the steering linkage gets contact with the tailshaft at the front
how do you guys go about this? shim it sits higher?
I presume that you mean the front upright. I now have the Aluminium Square part for that and I use the furthest hole to the rear of the car. Works a treat.
In regard to the tailshaft contact, I am actually using a turnbuckle instead of the carbon steering plate due to durability and I don't have that problem at all, unless I take a big hit.
Old 01-11-2005, 03:22 AM
  #2419
cooliomojo-CEBU's Avatar
im using profile number 2. yep, might be the profile. how is profile 5 on stock. i will be racing stock 23t this weekend. i dont think it is the batts.....i used all of my batts and it just felt a bit weird.
cooliomojo-CEBU is offline
Old 01-11-2005, 03:23 AM
  #2420
BrainTeased's Avatar
Default Re: Camber
Originally posted by Hebiki
Front: -1.5 to -2
Rear: -1 to -1.5
ahh thanks Hebiki!
no wonder my ass end was a little fishy.
ill try first
-1.5 front
and -1 rear and add more if i need it
BrainTeased is offline
Old 01-11-2005, 03:26 AM
  #2421
F. Alonso's Avatar
Okay, cool. Be sure to let us know how that goes. From what I've heard, Profiles 3-6 are the ones to go for. Try them out and see how you go. I have yet to REALLY test them out for sure.
Old 01-11-2005, 03:30 AM
  #2422
no no not the carbon steering plate that is hitting the tail shaft the actual steering link which has 2 ball cup ends on each end... ahhh to hard to explain!
but yea those square alloy hop ups are expensive!!! you must of spent a fortune!
also i noticed you advised 4 deg front c hubs does this give us more steering compared to the 2 deg?
Old 01-11-2005, 03:32 AM
  #2423
thx brainteased i fink i will definatly get the evo IV now...just waiting for my trip now...due in 3 weeks
kera_1 is offline
Old 01-11-2005, 03:36 AM
  #2424
F. Alonso's Avatar
Generally the tracks that we race on are bumpy and more camber is good for bumpy tracks. Also, I believe that they are better for rubbers too which is what we race here.
Because I use a turnbuckle instead of the carbon plate, this means that I can alter the ackerman by adjusting the size of the link with the turnbuckle. Because of this, I don't get that close to my front joint because my link is shorter then the carbon steering plate, if you know what I mean. When we catch up sometime, I'll have to show you. That will better explain it.
Old 01-11-2005, 09:08 AM
  #2425
Brainteased
Have a look at mine and see if you can see what the problem with yours is...
If you need anymore detail let me know..
Galifrey is offline
Old 01-11-2005, 03:22 PM
  #2426
thanks Gailfrey!!
but for some reason it looks like the middle steering rod is not coming in contact with the front shaft and i looked at your shims on the left hand side that is connected to the left steering arm post. looks like what i did. very strange and it does look like you have full lock to the left as well!!!
beats me!!! lol but thanks! ill be trying to add another shim to see what it does if it has enough thread.
Old 01-11-2005, 03:33 PM
  #2427
fraz's Avatar
Originally posted by Galifrey
Brainteased
He is talking about the threaded rod that goes from the servo saver to the steering bellcrank. I personally have not had a problem with that hitting but I set it up exactly like the manual said. You need to make sure that at neutral steering, the servo horn is over about 30 degrees to the right when looking at the spline and then you use the topmost hole in the servo saver. If you do this, it will not touch. Otherwise, I can see where the servo throw would be off and that threaded rod would touch the driveshaft.
FWIW, I ran on insane traction carpet this weekend and ended up running -2.5 in the front and -2 in the rear with foam tires. I finally got the tires wearing evenly!!!
fraz is offline
Old 01-11-2005, 04:05 PM
  #2428
jeffreylin's Avatar
thanks Gailfrey!!
Check if you have your steering crank installed wrong. if you look carefully you will see that the length is different on the two sides and the shape of the holes are different too.
jeffreylin is offline
Old 01-11-2005, 04:31 PM
  #2429
I think this pic will show what is wrong....
Bet he has used the middle hole on the servo saver rather than crank the horn over and use the end one...
Galifrey is offline
Old 01-11-2005, 07:36 PM
  #2430
hi guys
Jeff
i know what you mean while assembling it i noticed that and have done it the right way with the small hole facing towards the front and larger hole towards the rear.
Gailfrey
yes im using the outside hole facing to the left wheel! just like yours! :P ill get some pics done to show you guys
