Old 10-29-2004, 12:43 AM   #1696
EVOtech's Avatar
Originally posted by EVOtech
They are due out on 30th.
"If I'm not mistaken R10 will have the Tamiya alu cups today or tomorrow?! That's what I was told, as I have a pre-order with him"
I just looked, they have them:
0013400153785,TAMIYA,,500yen,53785 TB EVOLUTION 4 ALUMINUM CENTER CUP
0013400153786,TAMIYA,,600yen,53786 TB EVOLUTION 4 ALUMINUM ONE-PIECE FRONT CENTER CUP JOINT
I don't know if the latter is the same 'pattern' as the square one we have in the other car. If it is, then its a bit of a waste of time also doing the l/w front shaft. Does anyone have a picture of it??
EVOtech is offline   Reply With Quote
Old 10-29-2004, 03:28 AM   #1697
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Picked mine up yesterday on the 28th they look almost the same as the Square items.... ... I`ll take a pick to compare them side to side
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 10-29-2004, 04:40 AM   #1698
Hello
I want to replace this parts on my evo4 suspensions:
-TA51098 (2.6x22mm screw pin) because there's a big slop in the C hub. Maybe there's a manufacturer who makes it without slop?
(it's the same problem for the rear upright).
Let me know if you have a solution.
Hugo is offline   Reply With Quote
Old 10-29-2004, 05:28 AM   #1699
C van der Hagen's Avatar
just put a 0.1 mm shim between the wishbone and caster block.
C van der Hagen is offline   Reply With Quote
Old 10-29-2004, 05:36 AM   #1700
C van der Hagen
I know, but I'm not talking about this trouble, in fact the pin is too thin for the C hub. As if there is a shim, the c hub will move.
The size is said to be 2.6mm, I think it's 2.55mm in fact???
I'm looking for a solution.
thanks
Old 10-29-2004, 05:41 AM   #1701
Mine are exactly 2.6 mm and have no play.
Maybe your plastic parts are worn out?
Old 10-29-2004, 05:51 AM   #1702
No all my parts are brand new.
That's why it's a problem!!!
Do you know if the 500 shock oil tamiya is the same as 50 Asso?
Old 10-29-2004, 06:01 AM   #1703
TBH i prefered the 3mm hinge pins and the old suspension as i feel it was more precise than the new stuff. Rick
Rick Draper is offline   Reply With Quote
Old 10-29-2004, 06:32 AM   #1704
EVOtech's Avatar
-Dave
If they are the same (virtually) and Square ones are a lot more expensive...........
Old 10-29-2004, 06:40 AM   #1705
EVOtech's Avatar
-Dave
Don't take a pic Dave, someone might copy it
Old 10-29-2004, 06:41 AM   #1706
EVOtech's Avatar
Agreed. Nothing wrong with the old stuff.
Old 10-29-2004, 06:56 AM   #1707
Looking to sell all my Evo 4 parts and my evo 4. Please pm me for details, will post it all in for sale later. Rick
Old 10-29-2004, 06:58 AM   #1708
EVOtech's Avatar
Why you sell? I thought you were in love?
Old 10-29-2004, 07:25 AM   #1709
EVOtech's Avatar
Originally posted by fraz
Ballsie,
Take the mounting hardware off and just use reinforced strapping tape to secure your batteries. I tried everything possible to get the other mount to work and it's just not worth it. One good hit and your batteries will fly out and your race will be done. Just make sure to file the bottom edge of the tape slots so the tape won't get cut.
A little front to back play in the spur gear isn't too bad. I was going to shim it all out but have run the car that way many times with no adverse reactions. Loose is faster right?
Use a slightly bored out (reamed) Yoko MR4 battery bar. They don't move then.
Old 10-29-2004, 10:41 AM   #1710
Originally posted by Hugo
Hello
Nobody has a solution for me?
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
