Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 06-29-2005, 11:25 AM
  #10126
PW
PW's Avatar
Originally Posted by brians11
anyone know where rp-30s are in stock?
Schumacher has them in stock, so all shops have access to them
www.speedtechrc.com www.superiorhobbies.com
PW is offline
Old 06-29-2005, 11:42 AM
  #10127
Trader Rating: 40 (100%+)
thanks
brians11 is offline
Old 06-29-2005, 01:09 PM
  #10128
HarshGuy's Avatar
Originally Posted by pops
I carry this in my wallet...
OMG ...that's to funny, who is that apparantly well to do and influential chap anyhow?
Smash ...here's something for you to add to your signature line
HarshGuy is offline
Old 06-29-2005, 01:12 PM
  #10129
STLNLST's Avatar
Trader Rating: 32 (100%+)
Jack isn't a Schuie regular so he isn't going to get that joke.....LOL
PW- are the solid spools instock? I plan on placing a small order in the morning.
STLNLST is offline
Old 06-29-2005, 01:17 PM
  #10130
HarshGuy's Avatar
???? ..it's not a joke!
HarshGuy is offline
Old 06-29-2005, 01:56 PM
  #10131
PW
PW's Avatar
Yes, U2797 (alloy spool) is in stock
PW is offline
Old 06-29-2005, 02:06 PM
  #10132
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
That's right, going back to the spool after seeing the error in your One-Ways
Jon Kerr is offline
Old 06-29-2005, 02:17 PM
  #10133
AdrianM's Avatar
Don't make fun of STLNLST for going both ways! This is America!
Do what you like STLNLST! (Insert Digital Undergound background music: http://www.cduniverse.com/soundsampl...3Fobj%3Dv50131)
AdrianM is offline
Old 06-29-2005, 02:27 PM
  #10134
Jon Kerr's Avatar
Jon Kerr is offline
Old 06-29-2005, 02:29 PM
  #10135
hi
i race on sunday with my spool in,that i made up from the diff and in the 2nd race i snaped the right had outdrive off lol it snaped on the bearing so it made it verry hard to get the bearing off and get back into the nxt race but i made it.i dint evan hit anythink.so i am back to the diff now,
bob
bob33 is offline
Old 06-29-2005, 02:35 PM
  #10136
AdrianM's Avatar
Originally Posted by bob33
hi
bob
When you make a diff into a spool adjust it the same as a diff...full tight then back off 1/8 to 1/4 turn. If you hit something the out drive will slip and nothing will break. Even 1/4 loose from tight the diff output will never move unless you hit something.
How often you crash determines what you should run. The built up diff/spool may be a better option if you crash a lot.
AdrianM is offline
Old 06-29-2005, 02:43 PM
  #10137
Cole Trickle's Avatar
Default Ahhh, finally...
I've ordered my MI2.
Do you guys recommend any spare parts?
Our boards are pretty tough, so I was thinking about some spare A-arms, things like that...
The plan is pretty simple: Run it plain stock, and see how far I can take it. Later on, I'll maybe try a spool and/or a one-way.
Is there a recommended setup for carpet, rubber tires. Stock class exclusively. And no tire sauce at all. I'll probably start out with a boring-looking, nice handling Stratus, or something like that.
I do have a reasonablt selection of Schumacher springs, but I believe I'll be using my HPI springs, since I got a much better selection of these
Thanks.
Cole Trickle is offline
  #10138
i was runing it like that undone abit and i dint hit anythink so it must have just been week, but it is quit old now and has been used alot as a normal diff.so i dnt realy mind just suprised that it went like it did from not hiting anythink. but yeah i will gte the proper spool i just wanted to see if i liked the spool instead of bying a spool, bob
bob33 is offline
Old 06-29-2005, 09:06 PM
  #10139
seaball's Avatar
Thumbs up
seaball is offline
Old 06-29-2005, 10:08 PM
  #10140
Jon Kerr's Avatar
One thing that we hear a lot about any parts breaking is "I didn't hit anything" or "I didn't hit that hard" The problem is that there may have already been damage there from a previous hit that hadn't broken all the way. A cracked part may hold together enough that you wouldn't be able to tell but will break with the lightest hit or even just the load on it from driving. I've seen A-arms snap in mid corner before.
Jon Kerr is offline
