Schumacher Corner
#9376
New Paint for Donny!
WOW! I don't think I'll recognize Donny with a painted body! It looks pretty sweet! Now you know, you have to have a nicely painted body for the rest of the year, no more asphalt bodies!
Clint-You better print out that list and frame it because that's the only time you'll ever be on top! You could also tape it to your pit box so you could see it everytime you reach for a tool...lol!!
Are you going to the Ripon race next month before the Reedy? I'm planning on making a trip back to the old stomping ground, is anyone else going? Let me know.
See ya!
Pat
See ya!
Pat
#9377
Re: New Paint for Donny!
See ya!
Pat
See ya!
Pat
#9380
I want to say the ones i got where from Take off. At first they were just a little title but a loosened up after i introduced the exacto ;-)
Either way, Superior has them. Just ask Mike or Ben when you go in and tell them you want the ones Rashaad ordered.
#9383
Skittles
Sorry Clint,
The skittle bringer will not be with me. But I will try to bring Hodapp and Furutani if they'd like to go. Do you know if the race will be in the day time or night time like old times?
I've heard Nevada is liking his new Yokomo, what do you think?
#9384
I had my first race with the Mi2 last night and I was very impressed.
Whilst been down on horsepower (not due to the car), and competing against quite a few guys on foams (I was running rubbers) I still managed to finish 4th in the A Main (in stock) after qualifying 5th - even got to lead the race for a couple of laps
So now the questions
Does anyone know what other springs fit the standard shocks? I would like to run something softer than the kit Blue springs in the rear - but Schuie's Grey springs may be too soft (10 rate?).
I have some springs that I can try but they're a lot shorter than the kit springs - so I'm not sure if the shock collars can be screwed down far enough.
I was talking with another Mi2 driver about the riser plates and what effects this has on the car. My understanding is that lowering the suspension mounts on one end of the car will lower the roll centre, thereby improving the grip - Is this correct??
If this is correct, then why not simply remove the riser plates altogether from both ends of the car - theoretically increasing grip at both ends?
Finally, if I need more mid-corner steering on fairly tight corners - where should I look to make adjustments?
#9385
#9386
Re: Skittles
Sorry Clint,
Sorry Clint,
#9388
Ball Cups
Hey,
I noticed that a lot of the team guys are changing their ball cups from the stock ones that come with the Schu to bigger Losi looking ball cups. Is there a reason for this other than they are offered in Schu purple :-)?
R
R
#9389
You don't always want more grip. If you were to lower the roll centers too much, you could get the car really pushy. You'll hear people say the car is too stuck. Basically the car is not free enough to flow through the corners. Having the roll centers raised a little will usually help free the car up to flow through the corners better. If the car is pushing on entry, lower the front roll center, if you're loose on exit, lower the coll center. The opposite is also true, too aggressive on entry, raise the front, too tight middle to exit, raise it a little.
