Schumacher Corner
#8627
Originally posted by AdrianM
None, I want to reduce camber change.
The car is really good at my locak track. Really good turn in and rear rotation. It is a bit loose on power exiting but this weekend I might lean in the rear shocks or add some anti squat.
#8628
Hey Jon, you maybe have a spare rear diff pulley, stock one? I need it for my other car.
#8630
do i tighten down the sway bars so they dont move or do i leave them little loose?
#8631
Use a small piece of shrink tube to fit between the mounts.shrink it on the swaybar this works great to take away side to side play without adding weight.
#8632
spur +pinion
Now Im not asking for an exact number, just want to know where to start with a 10X1 in my Mi2 ?
cheers
cheers
#8634
Re: spur +pinion
cheers
cheers
64p- 124/27
48p- 95/21
These are gearings that work for me at a couple of tracks in my area. Is your track open, tight?
#8635
Track
Fairly tight at the moment. Using the 48p spur.
#8638
Freeing the drive train
Now i'm torn as to where to be this weekend. Most of the guys here (orlando) sound like they are going space coast. And from what i'm reading you guys are going speedline :-(. Either way,
I'm trying to free up my drive train a litle more since i have to back in my spool for this sunday and was wondering what tricks can you guys recommened for freeing it up. Right now as you guys now the dt is pretty free out of the box but i'm looking for that extra edge.
So what do you say? trim teeth on the rear belt? Remove shield from all my bearings? what is the prefered method here?
R.
R.
#8640
This is just my opinion. As long as the drivetrain isn't binding and is nice and smooth, I don't think making it spin like some of those shaft drive's you see that guys get to spin forever will really do much good. As long as there's nothing dragging and binding, I'd say you're fine.
